Ducane heater burners ignite but the fan won't turn , has a hum. fan will turn by hand.
    Scholar:
  • 79 Answers
There are 3 possible causes for this problem. Either you have low voltage to the motor, you should have 120 volts, or the run capacitor for this motor is defective, or the motor itself is defective (motor windings).If the motor is bad and you replace it make sure you replace the capacitor as well.
Posted on Nov 12, 2009
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
I have a one burner that doesn't ignite - what do I do?
Assuming the igniter to that burner is working properly, the best bet is that the burner is clogged an not getting gas. This will require removing the burner to clean it and the venturi valve (which is part of the burner), as it can become a haven for spiders.
Since removing the burners on a Ducane grill can be a bear to do. I have included a link to your Owner's Manual, in case you have misplaced yours, that you can download and print for future reference. Pay particular attention to the Annual Maintenance section. As it will walk you thru how to remove and clean the burners.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
I hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Jul 26, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
The burners do not light consistenly. I can see the igniter spark and the fuel supply is good. If the igniter does work the main burners may not light until I creat a draft then the burner takes off.
It sounds as if, the burners need to be removed and thoroughly cleaned. As do the Venturi valves on the open end of each burner. Spiders like to build nests in the Venturi openings and clog them up. It's a prat of Routine Maintenance, takes a little time to perform, but is not difficult to do. It does require removing the burner knobs and the control panel cover (which was a poor design by Ducane/Weber)
To help make this a little easier for you, I have included a link to a Ducane Stainless Steel Model Grill that will show you how to remove the burners. Pay particular attention to the Annual Maintenance section starting on page 21. You can download and print this manual for future reference.
Hope this helps you. Please let me know and Happy Grilling!!
May 25, 2011 | Ducane 30400040 Stainless Steel Grill
One burner wont light of the 3
Is the igniter not sparking or is gas not getting to that burner? Have you tried to match light that burner? Those three things is where you start troubleshooting the problem
If the igniter is not sparking, it could be that the igniter is covered with cooking grease or the wire to the igniter has come loose either at the igniter or the igniter module. And simply needs to be reattached (pushed back on).
If the burner won't match light, than it's not getting gas and should be removed and thoroughly cleaned. And while you're at it, remove and clean all the burners and the venturis valves.
Removing the buner burners on a Ducane grill is a bit of a task, so I have included a link to your Owners Manual to assist you. Pay particular attention to the section Annual Maintenance, starting on page # 28.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
May 10, 2011 | Ducane Affinity 3100
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
Heater just hums for a few seconds but will not ignite.The heater has not been running for some time.
When you say the heater hums is the fan turning? Providing the fan is turning remove the top cover on the heater. Turn the heater on and watch the back of the burner area. Do you see any fuel mist coming from the nozzle? Do you see the ignitor sparking or glowing. Providing you see the ignitor working check the air pressure on the back on the unit. Remove the plug on the back of the unit that does not have a hole drilled in it. Insert a gauge into the hole (1/8" pipe thread) The pressure should be 5 to 6 psi. Let me know what you find and I can tell you how to proceed from there.
Jan 02, 2010 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
