Question about Sharp R-1501 Microwave Oven
Nite Lites won't Lite
I've replaced these nite lites twice and they seem to blow out as soon as they are installed. This is just one of many problems with this oven. I'm suprised that Sharp hasn't owned up to taking care of their mistakes.
  • Sharp Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
How do I turn off the nightlight on the bottom of my microwave?
TheAuto Nite Light feature can be set to turn on and off at any time desired.Follow the directions below for set-up:
  1. Press the AUTO NITE LIGHT pad.
  2. Enter the time the light is to turn on. ...
  3. Press the AUTO NITE LIGHT pad again and enter the time the light is to turn off. ...
  4. Press the AUTO NITE LIGHT pad once again.
Sep 16, 2017 | Microwave Ovens
Advantium display reads "nite"
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 30, 2017 | GE Advantium 120 Convection/Microwave Oven
Ge spacemaker nite light will turn off
test the switch for defective and replace or clean the contacts. or course your must unpplugged the power before to test.
see the diagram attached.
God bless you
Jul 14, 2012 | Microwave Ovens
I had the electricity go out in the litchen last nite, and usually, I just go to the basement and reset the breaker. It didn't work last nite. Also, now when I turn on the electric range, a light in the...
It's not a ground problem, but more likely a weak or open neutral connection somewhere. This can cause damage to other connected devices because of excessive voltage, and should be taken care of quickly. You should have a licensed electrician check and repair this, both because it may be difficult to locate exactly where the problem is, and because your insurance policy will probably require repairs be done by qualified personnel.
Dec 30, 2010 | Microwave Ovens
Installed a new hmw9305 last nite, no power
Sounds like you blew the fuse. I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which explains the problem, how to correct it and where to get any parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Bosch HMV9305 Microwave Oven
Model r1200 sharp microwave display does not lite, have replaced twice and other people who have purchased have the same problem. Does the new version 2 color display replace my display
Sharp microwave is a very good unit. If you have done same repair twice before, i suggest replace board complete with display next time as there could very possibly be a set of defective components on the old board that is causing this display problem. Have done this repair before and noted how thin the tracks are also. Honestly go for new board if you can.
Sep 26, 2009 | Sharp R-510HW Microwave Oven
Spacesaver XL1800 Nite Lite will not go off
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site,
linked here on Fixya: http://tinyurl.com/yzjozk
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No lites and fan actions.
Does it heat? If so, then The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
The light failure often occurs when a bulb goes out and the filament shorts, causing a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 20, 2007 | LG LMVM1945 Microwave Oven
On replacing nite-lite/under hood bulb, 1 lead broke off in the socket
Be sure to disconnect the oven from the power line before removing or installing bulbs or working on it. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 22, 2007 | GE JVM1490 Convection/Microwave Oven
Light Bulb Replacement On JVM 1860SF001
You can find an exploded view diagram by entering your model number (without the space) here: http://www3.sears.com/ That diagram may help.
Mar 23, 2007 | GE JVM1860 Microwave Oven
Sharp R-1501 Microwave Oven Logo
42 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
