Question about Samsung TX-R2435 TV
When watching satellite or dvd the picture is black and white but i still get the blue screen and the tv setup menu has color. is it broken or fixable?
  • 3 Answers
There is a cable which controls the colour on some televisions. If this cable is removed from the television the picture will go black and white. Chances are it has been knocked out by accident or it has just worked its way out over a period of time. Either way try to locate it and put it firmly back in place.
Posted on Nov 12, 2009
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Bose 321 display is only Black and White..all movies too
Could just be the dvds? Or not...
Replace the laser that reads the discs!
Jul 07, 2009 | Bose 3 2 1 GSX System
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Dell W4201C, White screen on Power up (used to be Black).
Y SUS and Buffers are usual culprit.
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs!!!!
Apr 17, 2009 | Dell W4201C 42 in. Plasma HDTV
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
cheers,
mark
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
The color on my sony model #KP-51WS510 stopped working
I would go to the setup and check the setting for returning to factory defaults
Let me know if this helps
Dec 13, 2008 | Sony SCREW +PS 2X5 (BLK) (762825310)
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Portable DVD showing blue screen
i have the same dvd player the pink 1 i lent on a button and it went into black and white i have tried everything and can't seem to get it back into colour again, ive tried pressing all the buttons and nothing seems to work or come up with any black and white/ colour options :(
Mar 04, 2008 | Televison & Video
Black and white picture
Try going into player's menu, and set video out or TV type to NTSC.
It might have switched to PAL, or disc is PAL and player is set to any.
Dec 13, 2007 | Cyberhome CH-DVD 300 DVD Player
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Samsung TX-R2435 TV Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
