Question about Microsoft Wireless Notebook Optical Mouse VSBX300008
How do I install a new battery? - Microsoft Wireless Notebook Optical Mouse VSBX300008
  • 558 Answers
At the base of the mouse near to the middle there should be a small door.Slide towards the back this should reveal the battery.
Good Luck
Posted on Nov 12, 2009
    President:
  • 2,049 Answers
Look for the button on the bottom of the mouse (see red arrow) and push it. The battery compartment will open...
How do I install a new battery? The manual doesn' t cover this.
Many garden tractors have the battery located under the seat. Move the tractor to an area you can work easily in and shut off the ignition.
1 Access the battery / compartment.
2 Identify the (-) Negative and (+) terminals on the battery.
3 Note orientation of the battery (-) or (+) as it is installed in the tractor.
4 Place a piece of tape on the (-) battery cable's insulation and another near the (-) battery terminal.
5 Photograph the battery with cell phone, etc.
6 Remove any clamps or brackets if they will be in the way of removing cables.
7 Remove the (-) cable from the battery terminal first by loosening the bolt or screw with required wrench, battery pliers, screwdriver, etc. by lifting it up / sliding out of the terminal.
8 Remove the (+) cable from the battery terminal last by loosening the bolt or screw with required wrench, battery pliers, screwdriver, etc. by lifting it up / sliding out of the terminal.
9 Remove any clamps or brackets if not already done previously.
10 Lift the battery out of the compartment straight up without tilting to prevent spilling acid from the battery.
11 If acid is not already in new battery: place new battery on several layers thick of newspaper and
a add battery acid to new battery as per instructions included with the battery.
b Place caps on battery when filled.
12 Identify the (-) Negative and (+) terminals on the new battery.
13 Place a piece of tape near the new battery's (-) terminal.
Place battery into compartment so that it is in the same relative orientation as step #3 above. This will ensure both cables will reach the correct terminal on the battery.
13 Check installed battery to photo to be sure it is oriented correctly.
14 Install any clamps or brackets if they will not be in the way of installing cables.
15 Connect the (+) cable [no tape] to the (+) battery terminal [no tape].
16 Double check that the (+) connection is correct and tight.
17 Connect the (-) cable [with tape] to the (-) battery terminal [with tape].
18 Double check that the (+) connection is correct and tight.
19 Install any clamps or brackets if not previously done in step #14 above.
20 Dispose of newspaper, acid container, etc in trash.
21 Recycle old battery where new battery was purchased / collect deposit.
Done!
May 19, 2015 | Garden
Can a new car radio kill the battery?
Yes and that was due to bad installation. I have had 3 car stereos installed on my 98 RAV4 through Best Buy and never had battery problems. I even had 2 amps installed as well but the installers had to make me buy this 200-dollar thing that would not drain the battery.
If you are getting a drain through the radio's power supply it could eventually drain down the battery if it was improperly installed, I would pull the fuse for the radio and see if the drain continues, if the drain does not stop there is another short somewhere. To learn more :
http://www.xcardiag.com/wholesale/automotive-battery-analyser-vat-560-tool-536.html
May 16, 2012 | Cars & Trucks
How to install CMOS Batterie
  1. loosen the scew 1but do not remove it: look at the picture below
mabroukmedal_1.gif 2. free the connector of the bacup battery:
3. install the new backup battery
Nov 08, 2010 | IBM ThinkPad 600X Notebook
Unit has been installed for 2 weeks with a new battery when installed. Came home today, it was beeping. I pushed the middle button but it still keeps beeping.
new batteries are probably dying-- new doesnt mean they cant be faulty install new batteries and observe if problem returns quickly
Feb 04, 2010 | Kidde Nighthawk Combo Gas/co Detector
Alternator problem
1.You need to install a Fully charged battery, before you install a new alternator. Otherwise it will burn the alternator up.
2.I read what you typed about installing a new battery. Was the new battery fully charged, and was it installed before the new alternator?
No?
See number 1 above.
Sep 03, 2009 | 2004 Mazda 6
Need the steps to installing a new car battery in my 2003 impala.
First disconnect, NEGATIVE cable, than the positive cable. Than remove the bolt or strap that is securing battery. Then when you install new battery, Connect POSITIVE FIRST, then negative battery.
Make sure battery is charged before installing in vehicle. It will save lots of tear on altenator.
Jun 22, 2009 | 2003 Chevrolet Impala
I am installing a new battery in my Satellite A15S127
The new battery is defective then. If the new battery was working then the meter would be able to read into the battery and recognize how much power is left in it. the problem more then likely is that one of the cells in the new battery is bad and since the laptop can't see all off the cells then it thinks the new battery doesn't exist.
Jun 20, 2009 | Toshiba Satellite A15-S127 Notebook
My Dimage X31 Camera does not turn on even with new batteries.
Make sure that you have them installed the correct way +/- and also check that the old batteries didn't leak and cause corrosion on the battery connection tabs.
Mar 09, 2009 | Konica Minolta DiMAGE X31 Digital Camera
Intalling Sidekick II Battery
For a sidekick II? The battery is hardwired in. You need to disassemble to install a new battery. Sidekick 3's and above have removable batteries
Dec 08, 2007 | T-Mobile Sidekick ID Cellular Phone
Microsoft Wireless Notebook Optical Mouse VSBX300008 Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
