Question about Sony KV-27V36 27" TV
I have a Sony KV-27TS31 and the picture is colour saturated and it will not hold horizontally. This happens usually after it warms up. We have a good picture if we watch through the video channel - I mean through our DVD player. What is the problem?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
You have a bad circuit see a tech
Posted on Feb 25, 2010
Standby light blinks you hear the contactor clicking in set, no audio and no video displayed. sony kv-36Hs500 only looking for response if this is free of charge
this symptom is usually caused by a breakdown in power supply circuit or it may also be caused by a breakdown in the horizontal deflection circuits which includes horizontal oscillator, pre drive or drive circuits, horizontal output transformer, horizontal output transistor and high voltage circuits (flyback transformer). pls observe precautions in dealing with this high voltage circuits and if so happen you are not inclined with this kind of work, it is better for you to bring it to a qualified technician to avoid accident. good luck!
Jul 27, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Can colours be adjusted manually? Some TV stations vary in colour content. How do I change the colour values?
you might find the colour & saturation levels controls. using your remote to set that up, check the tv manual... if you don't have one, you can likely find one on-line by doing a few searches.
Goog Luck... Ian
Oct 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Sony trinitron tv kv type
The screen voltage adjustment should be on the back of the high voltage multiplier. It should be marked as "Screen", or "G2". Next to it, is the "Focus" adjustment.
Some models of Sony sets have two focus adjustments. This is for H and V focus.
When increasing the screen voltage will usually increase the wear factor of the electron-gun assembly in the CRT. This is because it is increasing the screen bias current.
When increasing the screen bias, the brightness will increase a little. When the CRT is weak, this may produce visible retrace lines more so than on a good working CRT. This is because the excessive screen current will stop allowing the electron-gun assembly to work at its proper cut-off level in order to allow the blanking drive to bias it off during the retrace period.
Increasing the screen bias will usually cause a shift in the colour temperature especially in the low level gray colours. This is because the AKG reference for the electron-gun biases will be offset due to the differences in the electron gun performance characteristics change.
Jerry G.
May 03, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color lines/no picture
Well, if you still had a good picture before it happened, I would repair it.
This problem is usually a small part in the horizontal circuits. The service charges may be high, but the parts cost should be low.
This is a large heavy set, If you take it yourself to a shop you will save on the service call.
Jan 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
