Question about Husqvarna Chain Saw 20" Bar
How do I access the fuel filter on the 455 Rancher chainsaw?
    Sergeant:
  • 302 Answers
You should be able to fish the pick-up tube out of the gas tank with a wire and the filter will be on the end of it.
Posted on Nov 12, 2009
Why rapid fuel consumpsion on the husqvrana 455 rancher?
There are only a few reasons, either the saw is running too rich on the carb settings ( i think you would know notice this due too poor engine performance ) or the air filter is blocked ( again this would effect engine performance ) or the the tank is leaking.
Oct 18, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
My rancher, reliable for many years, has developed the problem of starting but not continuing under acceleration via the hand trigger; it just cuts out.
This sounds like fuel starvation, start by replacing the fuel filter in the tank, check the fuel hose up to the carb for signs of leaking or cracks.
Aug 31, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher bogs down when i give it gas it's not even under a load new plug air filter, fuel filter, made carb adjustments like manual said running 93 octane gas.it,s still bogging
Make sure the chain break is releasing all the way. When the saw is not running release the chain break and make sure you can move the chain back and forth by hand. If you can there is a small fuel filter in the gas tank that should be replaced. Make sure the fuel lines are not spongy because they could collasp when the engine is running starving the carburetor for fuel.
Mar 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher has no power at full throttle, but will start and idle normal.
Check for plugged fuel filter, air cleaner, and muffler. Check the fuel lines for decay or other damage. Check the chain for proper oiling and not so tight that you can't turn it by hand. Hope this helps!
Nov 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw dies at full throttle, idles fine and works with half throttle
hi
check the fuel filter,clean the gas tank,the carburator ,check the fuel pump(not to be tired).the fine filter inside the carb under the fuel pumpand the sparkplug.
by for now savumihai71
Oct 29, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher engine bogging down and starting to smoke
Make sure you are using the correct fuel mix.
Check fuel tank vent, prone to blocking an can effect the performance
Clean air filter, check Spark plug.
Oct 03, 2010 | Husqvarna 455 Rancher 555cc 35 hp 20"...
I have a husky 455 rancher.never had a problem till today, worked fine this morning, now it iwll start but as soon as i put it under load it dies, cannot even rev the engine, it idles ok, but once i open...
When this has happened to me, it turned out to be a hole or crack in the fuel line. At the higher revs, more fuel is needed. The added "suction" for the higher demand pulls air into the line and the unit does not have enough fuel to run. Check for that first and also the fuel filter inside the tank. The filter might be clogged as well.
Keep us posted,
Dan
May 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 455 rancher. It was working
Take it right back to repair shop and have them fix under their warranty.
It is possible the fuel hasn't got to the carbureator due to plugged fuel filter or fuel finder OR an air leak in the fuel hose.
Sep 15, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Chain Saw 20" Bar Logo
143 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
