Question about Vacuums
Does not move on carpet. The roller bar is
Does not move on carpet. The roller bar is dragging like the belt is stretched, because its not broken, I looked at it.
    Brigadier General:
  • 4,088 Answers
Remove the roller from the head and check the end bearings for binding (note how the belt is attached). Remove all of the wound up thread, hair, and string from the entire roller. Clean the bearings and lightly oil with 3in1 or similar. Check the belt for worn or burned areas (replace if so). Belt should be tight when reassembled. Clean the air passages of any potential clogs. Make sure all of the wheels turn freely--if any problems, remove the same debris from the bearings and lightly oil. Wipe away any excess oil. Hope this helps.
Posted on Nov 12, 2009
I'm getting no suction and the brushes are not rotating
Hello! If you are using the cleaner on carpet, it is necessary for the brushes to rotate to assist the motor with maximum pick up. If your brushes are not spinning check the belt to make sure it isn't broken or stretched. The belt will need replacing about once a year. Below are steps for checking the belt on your U5399-900.
1. Place handle in low position and turn cleaner over so bottom side is up.
2. Remove the 4 screws. Lift off bottom plate.
3. Inspect the belt for rips and tears. If it is damaged in any way, broken or stretched replace the belt
This unit takes belt 38528033. Be sure you replace belt with genuine Hoover parts. Here is a link where you may go to order a replacement belt.
Service Center Locator
Hope this helps!
Jun 05, 2014 | Hoover U5399-900 WindTunnel Lite Upright...
Panasonic ecomax carpet bar won't drive
The first thing to check is make sure the belt is not broken or stretched. It is possible that a vacuum cleaner may need a new belt even if you just bought it. It may have been a year or more since it was assembled and had the belt installed. It may have spent some time in a warehouse and on the store shelf before making it to your home so the first thing to check is always the belt. If it has a stretch belt they must be stretched to almost twice their original length when installed on your vacuum and they lose elasticity. The rule of thumb in the vacuum industry is belts should be changed every three months for proper agitation. If the belt is not broken or stretched check to see if there may be something stuck in there preventing the brush roll from spinning freely.
Oct 24, 2013 | Panasonic Vacuums
Brand new dyson dc46 beater bar not working
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 09, 2013 | Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Is the roller suppose to continously go around when running? Doesn't seem to change mat in carpet when going over it. Doesn't seem to be much suction..
That means that you need to replace the belt. The belt is what turns the roller brush, and when it is stretched or worn it doesn't. You can get replacement belts here:
Replacement Vacuum Belts
Jan 03, 2010 | Vacuums
Roller brush stops spinning and vacuum makes noise. Brush will spin normally ok, until you use it on the rug.
That means that the belt is stretched and can't turn the brush against the resistance of the carpet. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 21, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt Keeps Coming Off
Replace the belt with afresh, proper sized one. Yours is stretched. It will be shiny on the underside. hoover belts are meant to fit snug. Check the bearings on the end of the brush roll to remove dirt and thread. The proper belt will need to be stretched into place using the brush for leverage. Likely that your low carpet is more dense causing enough drag to throw the stretched belt.
Sep 13, 2009 | Hoover U6616-900 WindTunnel Bagless...
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
