Question about Watts Onan Portable Generator - 5000 , Model# 6500
Cannot get generator to shut down, please
Cannot get generator to shut down/off, please tell me what to do.
  • smoore0102 Nov 12, 2009
    GE ZENITH CONTROL TRANSFER SWITCH CONNECTED TO K5W
    ONAN GENERATOR. CANNOT GET THE TRANSFER SWITCH TO
    TURN THE GENERATOR OFF.
    PLEASE HELP US TO SOLVE THIS PTROBLEM.
    THANKS!
  • 132 Answers
Run a wire from the plug to theframe and put a switch inline and that way when you turn the switch on it will ground out the plug
Posted on Nov 12, 2009
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
Jan 23, 2014 | Nest Learning Thermostat 2nd generation
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
I have no manual for my Powermate Generator and it has never been started. Any advice on type of oil, start up procedure, and maybe more important shutting it down?
1- oil type: when you buy it...tell them u want small generator oil...its all the same.
2- start up:turn the red button (on and off button) on(usually UP).
then i prefer choking the engine.
(make sure the feul knob is open)
then pull the string ...and when it starts runnin undo the choking immediaetly.
3- shut down:simply turn the red button off (usually DOWN)..it might keeps shaking...if so...then choke it again.
i hope i helped...send me an email for more details
Oct 10, 2009 | Coleman Powermate Premium Plus 6250W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
Engine cuts out when hot
every generator has an auto-shut down system that turns the engine off when over heated..u can dislocate the wire coming out of the engine and into the on/off switch...and then it till never shut off unless u tell it to....
but be carefull!!!!!!!!!!!!!:when u dislocate it...u r turnning off the auto-shut down system...so if the engine over-heats.. it will not shut down...
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 13, 2009 | Coleman Powermate Powermate 5000W...
D1105 kubota engine on generator overheating
Can you tell if it's really hot (water temp) ? Could be a bad sensor.
Jun 23, 2009 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.What could be responsible and what can i do? It shuts down about 30seconds after dispalying the fault.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
Jun 16, 2009 | Kipor Electrical Supplies
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
73 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
