Question about Maxtor Hard Drive
Take Two: I have an older Maxtor Hard Drive
Take Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and someone kindly answered and sent a picture that implied if I set the jumper shunt on pins #3 and #4 of the 10 pin jumper block that'd set it in the needed slave mode. Well, first I only have pin #4-no #3. I tried that and it booted up in Win 98. Same w #1 & #2, #5 & #6, as well as not installing the shunt on any pins. Puting the shunt on pins #7 & #8 as well as #9 and #10 (where it was on old computer) it does boot up as Win XP Pro but it does not show the old hard drive at all under "my computer". Any help? How do I set the old drive to slave?
Thanks
p.s. On the old drive's label it says: "Jumper J50" and "Master/Single On", and "Slave Off".
  • radhot51 Nov 12, 2009
    I don't understand the answer. How would I connect to USB?
    Problem Solver:
  • 4 Answers
Connect it on hardisk enclosure then removed all pins
then connect it usb this serves as an usb flashdisk
Posted on Nov 12, 2009
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Maxtor file transfer problems
well..it's possibly the case that the maxtor is looking for mp3 files that are compressed using a different algorithm than what you are sending to it. can you open an mp3 file, and look at the properties, then compare that to your mp3 file specs for your maxtor
Feb 19, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Can I put stuff from a comp. w/ a virus onto a maxtor hard drive
Yes, naturally it depends on the virus, what kind it is and where it is stored. Most of the time you can safely transfer files to another hard drive worry free. I would not use a program such as "Ghost" that copies all your system's drivers over. Only save necessary files, format your old hard drive and re-load everything.
Hope this helps,
Thanks
Jan 16, 2010 | Maxtor Hard Drive
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
I have an older Maxtor hard drive Model 90645D3. How do I put it in slave mode so that I can transfer files to my newer XP's hard drive? Thanks, Rad I think I have the rest of the process figured out.
Hello
At the back of the drive, you should be able to see the jumper setting. There must be a small jumper in as well. Have a look at the pic, and just set it to slave and you should be set.
Kind regards
Andrea
Nov 11, 2009 | Maxtor Hard Drive
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
I have a maxtor 90645d3 i need to make it my master drive...can u tell me the jumper settings plz
On the back of the drive you should see 3 groups of 2 pins. One probably already has the plastic jumper on it. They should be marked: m s cs. The m mis the master setting. s is slave & cs is cable select. Place the jumper onto the group of pins marked m & your drive is now set to master. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Maxtor Hard Drive
MAXTOR EXTERNAL HARD DRIVE
well..data files will transfer..program and operating system will not..
Oct 12, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
163 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
