Question about Brother HL-2040 Laser Printer
2040 keeps telling me it's offline disconnected everything and back again went to the printer icon clicked the buttons and told it everything is go at printing time the printer light goes off and there we are again and again where are the terms of use that I can see here? what am I agreeing to? is this a con?
  • 23 Answers
Your drum cartridge may be used up. Replace it.
Posted on Nov 12, 2009
Brother HL-2270DW printer shows offline and won't print
I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
So, on my pc I went to the start button then chose:
- Computer
- Network
- Double click your printer
- New print drivers will start to install
- Right click the icon that is a copy made of your printer setup
- Set this as your default printer
I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
Source(s):
https://answers.yahoo.com/question/index?qid=20140422184955AA0dJ7F
Jun 27, 2012 | Brother HL-2040 Laser Printer
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
How can I stop the printer,it keeps on printing
This is very little info to go on, but this is probably caused by a corrupted print job in your print queue. Power down and disconnect the printer. Go to the printer folder and double click on the printer icon. If you see a print job listed i the queue, make sure the title bar of the dialog box says "offline". If not, go to file, select use printer offline, and then right click on the print job and selet delete. If the job does not go away after a few tries, reboot the computer with the printer disconnected and try again after reboot if the job is still listed. Another way would be to try pressing the cancel button on the printer if you already haven't. More information would make it easier to give you more accurate info..
Sep 29, 2010 | Office Equipment & Supplies
How to you get your printer online to print
So, tell me, have you ever gone to print something out and you can't do it because you get an error message that says "Printer Offline?" It happens to the best of us, but that doesn't make it any less annoying! So, what can you do when this happens? Luckily, you have a few options you can try when you need to get your printer back "online." Would you like to hear about them? I thought you might. Well, keep reading and you will!
The first thing you should try is simply turning your printer off, wait a minute or so and then turn it back on. That may fix your problem right then and there. If not, try disconnecting the cable that hooks into your computer and then reconnect it. After you do that, you'll also want to restart your computer to make sure everything lines back up. If you're still having trouble after that, try sending something to your printer to print and when you see the printer icon pop up in your taskbar, double click on it. Then go to the File menu and make sure the option of "Work Offline" is unchecked.
Another thing you can try is right clicking on that printer icon and clicking the choice that says "Set printer online." Or, if all else fails, there may be an actual button on your printer that can help you get it connected again. If your printer has one, it will say something like "Online" and you can press that button to reconnect your printer so that it will print once again. Now, all printers are different, so don't hold me to that, but if your printer does have that button, it's an easy fix for this type of problem. Hopefully your printer situation can be fixed with one of these suggestions, but if not, you can always refer to your user manual or contact the manufacturer for additional help. Good luck, my printing friends!
Dec 29, 2009 | Computers & Internet
Offline
change the data cable of ur printer
Sep 12, 2009 | Brother HL-2040 Laser Printer
Printer is showing offline and it's connected properly. what to do?
If you "right click" on the printer icon, is there an option to "use printer Online", If so click it, and the problem should be solved. If it just says "use printer offline" then that is not the problem, and I suggest re-installing the software.
Please let me know
Jul 04, 2009 | Brother HL-2040 Laser Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Printer says offline how do i get it online?
dear customer,
Please Rate the Solution.. Thank You..
Jul 10, 2008 | Office Equipment & Supplies
Hp deskjet f340 series keep showing offline
hi,
follow the steps:
>unplug the usb cable from the back of the printer
> go to the printers folder inside the control panel
> right click on the printer icon and then click on delete.
> if the printer icon is deleted and if there are no more printer icons related to your printer, plug the usb cable back to the printer and wait for few minutes while it automatically installs the driver.
NB: if you are unable to delete the printer icon. then right click and click on "pause printing" and then again right click and clear the documents in queue. if it is done then delete it.
if you are unable to clean the documents in queue, then
click on Start-->Run, type "services.msc" and click ok.
Double click on print spoolers and then click on "Stop" and then click on "Start". Restart the computer. then try to delete the printer icon.
Thanks and regards,
Agnel
Feb 29, 2008 | HP Deskjet F340 All-In-One Printer
Brother HL-2040 Laser Printer Logo
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
