Question about Nokia 5800 XpressMusic Smartphone
I have a nokia 6120c that turns off when I press any key, could it be firmware, settings or pcb board?
Nokia 6120c 1 unlock
Here's a method that requires you to call your provider for a pin key : http://www.burak.me.uk/forum/comments.php?DiscussionID=17
but here's a site that hopeefully works without the provider
http://www.superunlockcodes.com/nokia-6120c/rs12wp9/
Jun 21, 2013 | Cell Phones
Unlock code for nokia 6120c
Hi, You can get the unlock code for a Nokia 6120C from www.unlocking4u.com/nokia-6120c/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 6120C,
1 - Switch on your Nokia 6120C without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6120C.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6120C would then display the message "SIM Restriction Off" and will be unlocked!
Sep 14, 2012 | Cell Phones
How to format nokia 6120c?
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Format it
Sep 11, 2012 | Nokia 6120 classic Cellular Phone
Lcg jukebox v.2.73 s60v3 key?
Lcg jukebox v.2.73 s60v3 key? My phone nokia e5-00 IMEI:358631045480472
Aug 23, 2012 | Cell Phones
Nokia 6120c-1 board short
If the main board is short there is not much that can be done than to replace the board only if the cost suits.
If the short is in the power section it can be removed but it will need good implements to work and rectify.
consult with Nokai care
Apr 01, 2011 | Nokia 6120
DOWNLOAD STANDBY ERROR
I believe this is just a glitch in the copier. You need to do a printer reset. I do believe this will get rid of all the internal information of the copier -addresses, network setting, etc. Hopefully someone printed out the data lists after the intial install. Press the additional function key, 2 key, 8 key, additional function key. Press the left arrow key, below the display, until #CLEAR comes up. Press OK, then left arrow until ALL. Press OK. Then wait and copier will cycle. Hopefully all is well then. You will ahve to intall all, settings as a new install. Good luck.
Dec 06, 2010 | Canon imageRUNNER 1023iF Black and White...
I can't turn my Nokia 6120c on
Hi! I ve got the same problem with thee nokia phones!
Does your phone support the covering of phone? if yes you can take it off and look at the button off/on may be it is broken or tattered off??
Apr 06, 2009 | Nokia 6120
Nokia 6120c won't active after long standby
plug into car charger and leave for 1 hour, this will blast power in to phone the remove battery reconect batery and try
Nov 29, 2008 | Nokia 6120
Nokia 5800 XpressMusic Smartphone Logo
95 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
