Question about Canon GL2 Mini DV Digital Camcorder
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
    Problem Solver:
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Posted on Dec 20, 2009
How to connect canon gl-2 camcorder to computer
Are you using the proper Firewire cable to connect? Also, the GL2 has had issue with the Firewire port going bad. Try a different cable and see if that helps. It can't be a USB-Firewire cable either.
Sep 07, 2014 | Canon GL2 Mini DV Digital Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I have tried to connect my Canon XM2 to my IMac via firewire, but it is not 'seen' by IMovie, FCE or FCP, so I can't capture anything. Thanks
Open the System Profiler on the Mac and establish if the camera is connected to the Mac's firewire BUS. If not, try another cable and also test is the camera's firewire port is working. It's either a cable or socket issue. Some cameras require that the menu of the camera be set to output over firewire, check this as well.
May 05, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
Not sure what cord to use to connect my mini dv to my mac.
Depends on the Mac unit you have. If your MAC has a firewire 400 port, then use the firewire cable that came with your camera. Just connect the cable to the camera and the other end to the mac. iMovieHD is already loaded - with the camcorder in "Play" mode, you will "Import" the video.
If your Mac does not have a firewire 400 and just a firewire 800, you need an adapter. Click on this link to see that adapter.
Thank you for using Fixya and your generous rating will be much appreciated.
Oct 20, 2010 | Canon ZR800 Mini DV Digital Camcorder
I need to import video from my canon zr500 to my pc
Hi!
You can import videos from your camcorder to your PC using a DV cable. Check this page from the user guide of your camcorder.
Basically, you need a firewire port and a DV cable. Most computers (new ones) already have firewire ports (or 1394 ports).
I hope that helps.
Good luck and have a nice day!
Nov 22, 2008 | Canon ZR500 Mini DV Digital Camcorder
Using GL2 as a webcam
Using the firewire/IEEE cord attach the camera to your computer.  If you are using a Mac it should instantly recognize the external camera when you open iSight or what ever utility you are using to communicate.  If you are using a Windows based computer open MS Moviemaker and it will recognize the camera as well by selecting capture -- once the camera is recognized you should be able to broadcast with it.  If you are using uStream.com sometimes your video capture interferes with the ability to broadcast.  In that case hook up the camera using firewire, connect to uStream -- grant uStream permission to capture using the camera then you can see the video in your browser window.
Oct 16, 2008 | Canon GL2 Mini DV Digital Camcorder
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
Dumping video
purchase a firewire cable to go from dv port of cam to computer-4-4pin for laptops 4-6 pin for mac and towers if comp has no firewire port-use pinnacle dazzle to convert a/v output to usb 2.o
May 17, 2008 | Canon ZR100 Mini DV Digital Camcorder
Connection
A digital video camera may be connected to a computer using an optional OHCI compatible, digital video capture kit available commercially. These kits must be capable of using the IEEE1394 (FireWire) interface to enable you to import digital video signal and still images into your computer. For those models equipped with a separate USB port, the camcorder may also be connected to a computer via its mini-B USB port, for downloading still images recorded on the SD/MMC card.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
840 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
