Question about SanDisk Sansa e260 MP3 Player
Turns on next second going blank looks lake lost the drivers oly stays on
  • 10,421 Answers
My kindle fire will not stay turned on! When i hit the on button it seems like its going to go but then the screen goes blank!
Did you try with power plug on ? If ok, the battery is gone. If not, try restarting (keep POWER button pressed several seconds and after few seconds press once). If you see the logo on screen and then black, look in a very dark room to adjust luminosity setting.
Sep 10, 2017 | Tablets & eReaders
Manaul for wipers for kb250 isuzu 1999 model
Sorry no idea with a look myself ,the wipers staying on is caused by the self park mechanism inside the motor unit breaking off but why a new motor isnt working i have no idea other than to check the plug connection on the motor
Jan 18, 2015 | Isuzu Cars & Trucks
My Packard Bell switches on but the screen stays blank
The first thing you need to do is shut off the laptop. The next step you should take is to disconnect the power cord and remove the battery. You should then hold the power button for 20 seconds. You can now reconnect the battery. You should now power it on and it should hopefully turn on. If this does not fix the issue you should use the FN key and hit any of the "F" keys that look like a screen. If this does not work you may need to contact Packard Bell for further support.
Mar 16, 2014 | Computers & Internet
I have a chamberlain garrage door opener i adjusted it so it will go up all the way but it wont go down all the way it stays up about 2 feet and on the second on its the opposite it goes down all the way...
Sounds like your door may be binding. Release the opener from the door and operate it by hand. It should move freely. It should also stay in place when you release it at about waist level.
Dec 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Blank Screen
Any bulged capacitor is a failed capacitor. The nice-looking ones next to the bulged ones have failed too since they are in the same circuit.
The real fix is to replace ALL the Electrolytic capacitors. You can use ones with slightly higher voltage ratings without problems provided that they will fit.You can use two 470's to replace a 1000 provided you can fit them in.
There may also be a 47mf/25 volt cap off to itself. Replace it too, if it fails, the unit will just not come on at all.
Dec 21, 2009 | IBM ThinkVision L170 17" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sharp's Vista Driver does not install
I had to add a printer manually after going through the driver installation process. Add printer,next,local printer (do not check plug and play),next,create new tcp/ip port, next, type in the printer ip address, next, I used the Generic network card here and it worked fine for me. You can figure it out from here
- Oli
Nov 25, 2008 | Sharp AL-1551CS Printer
Whilst using my computer the monitor went blank. I turned the monitor off and back on. It stayed on for less than a second before going blank again. There was power to the monitor. I left it for a few...
can u boot into the safe mode and see if the monitor will work cause it sounds like to me that you either have a driver that is failing or the monitor is failing
Aug 18, 2008 | HP Computers & Internet
SanDisk Sansa e260 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
