Question about Linksys Wireless-G WRT54G Router
All the ethernet ports light up and flicker when I plug in the power but the power and WLAN lights do not come on. This seems intermittant but it has been off for a long period of time this time.
    Problem Solver:
  • 8 Answers
Try resetting it by holding reset button for at least 15 seconds. should have reset, if not just try another button for factory reset. if computer does not pick up on wireless signal then might be hardware prob.
Posted on Dec 03, 2009
Apparently wireless works, but not the wired network
If your computer is plug in to one of the ethernet ports that should light up. If not you can try another computer or try another ethernet cable. There is possibility that the port is busted.
You can perform a reset on your router and see if the status of the lights change.
If you think your router is still under warranty , you can call linksys support at 1800linksys .. They will be able to diagnosed the problem with your unit, if its faulty or not.
Cheers,
KA
Jul 05, 2010 | Linksys Wireless-G WRT54G Router
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at http://192.168.1.1
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
Wlan lights off and now wirless access
Does your computer say Network cable unplugged?
If the wlan light is off, it means that your computer is not being detected by your router. You can try unplugging and replugging the ethernet cable at the back of the computer. Make sure that you hear a 'click' when you plug it back in to make sure tha it is properly seated. Check also the light on the wan port (desktops usually have lights..not sure about laptops though).
Do the same process with the ethernet cable but now from the other end--the one connected to the modem/router. if your modem/router have other ports on it, try to connect it to other ports as well. If you're wan light is still off, try using a different ethernet cable.
what's wrong with your wireless access? i can't read it from the title.
May 04, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
My netgear power light is on but the other light flicker like the check mark and i get a network cable is unplugged?
a: your connection is bad
b: your cord is bad
c: the connection is going out
you can remove the ethernet cable from the router and plug it into another port to see if that solves the problem.
you can check the ethernet connection on the back of the pc. unplug it and put it back. if you have a second port try using it and enabling the other network connection under the network connections icon.
Nov 30, 2008 | NetGear WGT624 Wireless Router
Connecting my router
Ok, so the ethernet port on your DSL or Cable modem has to be connected to the WAN port on the router first and foremost. Then I would suggest that you connect the ethernet port on the laptop to port 1 on the router, and attempt to log in that way. Bring up your browser (Internet Exploder, Netscape, etc.) and type 192.168.1.1 (if that doesn't work try 192.168.0.1, Linksys switches it up) in the adress bar... and ensure that you can get in that way. Then try surfing the web to see if it connects correctly... although you may need to speak to your Internet Service Provider to ensure that they are allowing your MAC Address to connect to their Network... the one under the WAN settings, NOT the LAN settings. It should look like this... MAC Address: 00:01:81:52:3f:99
Sep 08, 2007 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G WRT54G Router Logo
133 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
