Question about Garden
I have a garden weed eater tractor and the engines starts ok, but when I release the clutch or when I try to make the blades work, the engine stops.
SOURCE: ENGINE STALLS WHEN I RELEASE CLUTCH
The seat switch was stuck
thanks
Posted on Apr 06, 2009
bbreton
  • 437 Answers
SOURCE: garden tractor shuts down when you PTO on or release brake
You have a safety switch or a relay malfunctioning. Try going to www.partsdirect.com, this is sears website. Look at the diagram to see how many safety switch on this unit. You may get lucky and replace one or you may have to replace all. I would look to see if it has a safety relay first, try replacing that first.
Posted on Sep 30, 2009
Mike258
  • 1498 Answers
SOURCE: release clutch/ brake pedal engine stops / as well
Hi Carl,
Just had this happen to me. The mower had sat all winter. During that time a couple bearings froze up.
It took a pipe wrench to free them up.
I worked in some oil and that solved it.
You need to check each pulley and bearing to see if you can spin it. If you can't, oil it first, then try to **** it free.
Once it lets go, a little more oil and you are all set.
Best regards
Mike
Posted on May 04, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
  • 760 Answers
SOURCE: Garden tractor engine shuts off
Sounds like the operator present seat switch is not working. You can run the motor out of the seat, but not with the blades engaged. You didn't list what model, but usually hte seat switch is connected to the negative side of the battery, and grounds out the magneto, so you can't test it to ground. Put your tester on 12+ battery, and then to both sides of the seat switch. There is usually 4 terminals on seat switch. Some moodels have grey wires for the mageneto circuit, you can tell by whatever color also goes to the clutch switch too.
Posted on Aug 02, 2010
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
TB575 es 4 stroke -- head won't stop spinning. It's like its on a straight saft to the engine.
Your clutch has failed. Most common reason is a broken clutch spring, but sometimes a shoe will break. To get to your clutch, you need to separate the engine from the shaft at the front face of the engine, NOT where the shaft enters the engine housing.
Sep 28, 2017 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Hi i have a echo weed eater. It starts with only a couple of pulls and the runs great and sounds great. when i have the head up in the air it spins rather quickly but when i hit grass the head starts to...
check the cable that runs through the shaft from engine to head, it may be brocken or striped but when theres no pressure on the head it spins ok
Jul 24, 2011 | Garden
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman Model 917.259566 Tractor starts perfectly, but stalls out when the clutch is released. Whats happening?
Most likely your seat safety switch is not working. In order for the engine to run with blade engaged, the operator present switch must be made when the brake is taken off (releasing clutch).
Oct 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine stops
Hello
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Release clutch/ brake pedal engine stops / as well engage clutch lever for mover / engine stops. Thank you for taking my question . engine runs well no problem starting engine stops when place mower in...
Hi Carl,
Best regards
Mike
Engine dies
I would think more than likly your seat switch is bad. Try disconnecting the switch, do not jump, and see if it works ok. If not, then jump the switch.
Depending how old the tractor is, the switch can work either way.
Good luck, let me know.
Regards,
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
