Question about Motorola Mobility Hint QA30 Cell Phone
Hint and memory card error
I have a Motorola Hint, and after formatting the memory card in the phone my computer doesn't reconize it... also is the USB cable s'pose to do more than charge the phone?
My motorola hint screen just turned black while i was on it and i cant see anything but i can still call and get incoming calls i just cant see anything!!! Plz help
It is possible that the LCD display has failed or the linking cord has lost contact . remove to check . Also try and reset the phone . So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If there is no display take a consensus.Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Thank You for using Fixya
Aug 19, 2011 | Motorola Mobility Hint QA30 Cell Phone
Motorola Hint QA30 phone keeps re-starting over and over again. Don't have to move it, touch anything, nothing. Just does it on its own. Sometimes phone won't work for hours as it does this.
Hi, FORMATTING PHONE WITH VIRUS AND ALWAYS RESTARTING
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 07, 2010 | Motorola Mobility Hint QA30 Cell Phone
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My computer cant read the files on my m2 memory card. But when i look at it on my phone it has files on it what should i do?
the card has a format error in it because it has items on it that a computer does not reconize and a phone does such as a file extension
Oct 19, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Formating memory card
You can take you memory card out of the phone, put it in a card reader and format it from your computer.
Most laptops today has a built in memory card reader.
Sep 02, 2009 | Motorola Mobility MOTO U9 Pink Cellular...
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
Motorola V360 -Memory card slot error
Hai Dud,
Are you using Micro SD transflsh memory??
Format the Card on the PC using FAT, after that use a CARDREADER and put these folders on the card: MOBILE and in the mobile folder put audio, video, kjava, picture, temp! Shutdown your Motorola, remove the backcover and plug-in the card! After that Start Your Motorola and copy a file from the mobile's memory on the CARD! It should work!
Hope it Helped You,If so give an "High Five!" [;)]
Aug 04, 2009 | Motorola Mobility V360 Cellular Phone
How to format my 4gb memory card for my motorola phone using my kodak easyshare camera
You don't mention what model of Motorola phone you have, but most (if not all) that accept a memory card have a format option. I would use the phone format function rather than the camera.
Aug 02, 2009 | SanDisk 4GB microSDHC Memory Card
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Need help in getting my phone to reconize the memory card
Try formatting the card.
Put the card into your computer so you can view it and everything on it. Take all the files off the memory card and store them someplace on your computer.
Go to MY COMPUTER, right click the memory card and click FORMAT. Follow the directions and make sure QUICK FORMAT is NOT ticked. Then click format and give it a few minutes.
When it is done, put the memory card into your phone and see if it recognizes it now.
IF IT DOES, put the card back into your computer and put the files back onto the card. Then put it back in the phone. Should work now, if not, there is a defective file on the card and needs to be found because its interrupting the the phones processing.
IF IT DOESNT, try another memory card. The current card could be defective. If the phone still doesn't read the new card, the phones card reader is defective and needs to be sent to your phone provider to be fixed.
Hope this helps!
Have a nice day!
- Neal
Apr 27, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Mobility Hint QA30 Cell Phone Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
