Question about Cell Phones
I can't get my palm pre to sync with windows media player to add music
How do you download music
Hi stetsoncowgi...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me
Aug 23, 2011 | Coby Audio Players & Recorders
How to add music it did not come with a manual
Hi oliviamoore...
Free Answer...Please take time to rate me
Jul 09, 2011 | Audio Players & Recorders
How do you add songs on device
Hi atiug b...
Jun 11, 2011 | SanDisk Sansa Clip MP3 Player
How do i transfer music from my sansa clip to my computer
Syncing and transferring music files to the Sansa player using Windows Media Player 10 How do I sync or transfer music files to/from my Sansa player using Windows Media Player?
STEP 1 - Connect the Sansa player to the computer
STEP 2 - Run Windows Media Player
1. Go to Start > Programs > Windows Media Player.
NOTE: If you can not see Windows Media Player on the menu, go to Start > Run then type WMPLAYER then OK.
STEP 3 - Sync files to the Sansa player.
1. Click the Library tab.
2. Drag the music files to be transferred on to the right panel.
NOTE: You can also right-click on the title of the song and select Add to sync list.
3. After creating the list, click the Start sync button to sync and transfer music files to your device.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | SanDisk Sansa Clip MP3 Player
I do not know how to add music to my mp3 player.
Hi crystal 1299...
5...Plug in your MP3 player to the computer using your data cord, besure Windows Media Player is on.
6...Windows Media Player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Jun 01, 2011 | Sylvania Audio Players & Recorders
Adding songs
When you sync, you are telling Windows Media player to make the player match what is currently in your sync list. So if you removed the first 110 from your Windows Media, that is why they disappeared from the player.
You don't need to use Windows Media player to add songs. Simply open Windows explorer, double-click your Sandisk device, double click the music folder, then drag and drop any files you want into the folder.
Dec 31, 2008 | SanDisk Sansa e260 MP3 Player
I can't add music to my gogear
Plug in the Philips GoGear to your computer. Use aUSB cable to make the connection so you can begin synchronizing yourmusic collection.
Step2 Start Windows Mediamag-glass_10x10.gifPlayer. Depending on how your computer is set up, this program maystart automatically when you make the connection with the MP3 player.
Step3Find the Sync tab in the media player window. Click on this tab andopen the Sync screen. The Sync screen has two panes. The left pane isfor the music collection on your computer; the right pane is for thePhilips GoGear.
Step4Choose the songs from your collection that you want to add to theGoGear’s memory. Check the boxes that are presented by each song title.
Step5 Click the "Start Sync" button. The files from your computer are being copied onto your GoGear MP3 player.
Step6 Wait for the sync to complete. You can monitor the progress in the "Windows Media Player" window.
Step7 Close the media player program. Unplug your Philips GoGear from the computer.
Dec 28, 2008 | Philips GoGear SA5285/37 Digital Media...
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
NEED A LITTLE DIRECTIONS ON HOW TO TRANSFER MUSIC FROM MY COMPUTER TO MY TREO755P
You need a mini SD card do to this. If you are using windows media player it will be the easiest to sync:
Step 1: Insert MiniSD into the computer
Step 2: Open Windows Media Player
Windows Media Player should detect the MiniSD
Step 3: Go to the sync menu in Windows Media Player
Step 4: Make sure the music is selected and library, if you do not have your songs here, (using limewire or something, you can add them to your library; Where it says library on top go below it and an arrow should appear and click it, scroll down to add library and select the option you want ans search all of them, your music shoudl be added to WM)
Step 5: Select your songs and drag onto the right side
Step 6: After you selected all the songs click start sync at the bottom
Jan 05, 2008 | Palm Treo 755p Smartphone
Can't get music OFF my Craig.
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Nov 15, 2007 | iLO (2 GB) MP3 Player
Cell Phones Logo
64 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
