Question about Sony KDS-60A2000 60" HDTV
Blinking red light 3 times - Sony KDS-60A2000 60" HDTV
    Top Expert:
  • Sony Master
  • 14,553 Answers
A lot of these sets had a stupid problem---3 blinks usually means "the lamp door is not properly closed".
What happens here is heat from the lamp warps the door---it has on the back a peg of plastic that when it is installed engages a lever switch--protection so the set cannot be operated with the door off.
If you remove the door and look at it---if it is bowed a little it is most likely your problem---There is a easy way to prove this---with the door removed engage the switch with something not metal ( a plastic shaft or wood match) so the lever which is visable is engaged.
If the set comes on this way--you need to replace the door----There are places on the net and Ebay that sell a replacement---DO NOT BY PASS THE SWITCH AND PUT THE LARGE PLASTIC FRONT PIECE BACK ON---YOU MAY MELT IT ALSO--THE DANGER OF LONG TERM OPERATION WITH THE SWITCH BYPASSED AND THE LAMP EXPOSED IS THE LAMP GETS VERY BRIGHT AND HOT--DO NOT LOOK AT IT DIRECTLY.
Let me know what you find and if you need more help let me know--I am here to help people.
If this has helped you rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 12, 2009
  • tim9587 Nov 16, 2010
    What if I broke the switch when installing the door??? Am I hosed?
Slinteriors
  • 8617 Answers
SOURCE: turn tv on tv nothing happend red light blinks 3
O would need the model number to assist you, as the s blinks is an error code, but error codes are model specific.
Posted on Nov 26, 2009
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Feb 20, 2008
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
  • 556 Answers
SOURCE: light blink 3 times
If this is a Sony dlp then check the lamp door for warp, if this is not a Sony need model and brand. Or if it is a Sony but not a DLP then still need model.
Posted on Sep 14, 2009
Testimonial: "solved my problem with the three blinks, now i have five blinks"
welcomejee
  • 10594 Answers
SOURCE: tv not comming on red light blink 3 times stop
I do not agree with previous expert solution because it is not power supply/ power board failure in tv.
I think lamp was taken out from tv or may be it was replaced.
Check lamp cover in your Sony tv that is not fixed properly on its position. Make sure lamp cover is fixed securely.
Posted on Sep 14, 2010
Green orange then red flashing 3 times light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 04, 2014 | Televison & Video
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
Apr 20, 2012 | Televison & Video
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Light blink 3 times
Sep 13, 2009 | Sony KDF-50E2000 50" HDTV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDS-60A2000 60" HDTV Logo
417 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
