Question about VK Mobile VK2000 Cellular Phone
How do I unlock the menu options on my vk2000 phone? It's asking for a password before I call use menu options or place a call, though I can receive calls.
Removing encryption key
To open a locked memory card, select Options > Unlock memory card. Enter the password.
If you cannot recall the password to unlock a locked
memory card, you may reformat the card, in which case
the card is unlocked and password removed.
Formatting a memory card destroys all data stored on
the card.
Encryption
Select Menu > Tools > Encryption.
Encrypt your device or memory card to prevent
outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory.
To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If
you select this option, you cannot use the memory
card in other devices, and if you restore factory
settings, you cannot decrypt the memory card.
Encrypt and save key
• and save the key manually in the default folder. For
security, store the key to a safe place outside the
device. For example, you can send the key to your
computer. Enter a pass phrase for the key and a
name for the key file. The pass phrase should be long
and complex.
Encrypt with restored key - Encrypt the memory
• card with a key you have received. Select the key file,
and enter the pass phrase
Oct 19, 2013 | Nokia E63 Cell Phone
SGH-D807 HOW TO UNLOCK MY PHONE
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000). Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding. 2. Put a SIM card that is from a network other than the one your phone is locked to 3. When Incorrect SIM error comes up, type *#9998*3323#. 4. White screen will appear with an exit option. Press the right softkey. (just keep pushing the down key to get a menu) 5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear. 6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear. 7. Turn off your phone and put the original SIM back in. 8. Turn on your phone. You will receive a prompt to enter a password. 9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on) 10. Completed. You have now unlocked your phone.
Aug 01, 2011 | Cell Phones
Forgot my four digit unlock code
Your phone's 4-digit unlock code is originally set to the last 4 digits of your phone number, and the 6-digit security code is originally set to 000000. Your service provider may reset these codes before you receive your phone. If your service provider has not reset these codes, we recommend that you change them to prevent others from accessing your personal information. The unlock code must contain 4 digits, and the security code must contain 6 digits.
If you forget your unlock code, try entering 1234 or the last 4 digits of your phone number. If that does not work, press the menu key, in most of the phones this will bypass the unlock code screen, and the phone will now be asking for the security code. If you forget the security code, send your unit in for repair to a level three LSC. There could be a charge for this as it is not covered under warranty.
To change a code or password:
  • Press the Menu key
  • Use the Navigation Key to scroll to Settings, and select this option
  • Scroll to Security and select this option
  • Scroll to New Passwords and select this option
  • Select the type of code you wish to change
  • Enter the old code when prompted, then enter the new code
  • If you forget your SIM lock, or call barring password, please contact your service provider.
Mar 05, 2011 | Cell Phones
I forgot my memory card password , what is the solution?
This is what I did to unlock a memory card password in my nokia phone. You can try it in yours First is you unlock the phone
      1. Turn off the phone and insert the memory card into the memory card slot. Turn the phone back on.Press the "Menu" button on the main screen and click on the option for "Extras."
      2. Scroll down to the bottom of the list. Click the selection for "Memory Card."
      3. Select the "Options" icon on the screen. Scroll through the list to the "Unlock Memory Card" option and press "OK."
      4. Type in the unlock password in the password field. If you do not know the password, the default unlock code is either "12345" or "1357."
        • Delete the Memory Card Password
      1. Turn off the phone and insert the memory card into the memory card slot. Turn the phone back on.Press the "Menu" button on the main screen and click on the option for "Fun & Apps."
      2. Navigate to the option for "Gallery" and click on the "OK" button. Scroll to the "Memory Card" item and then click on "Options." Scroll to "Memory Card."
      3. Click "Delete Password" when the window prompt appears. Make sure the message "Memory card will be unlocked, do you want to continue" appears. Click on the option for "Yes" to confirm.
      4. Scroll down to the password field and enter in the default password. If you do not know the password, the default unlock code is either "12345" or "1357." Click "OK" to delete the password from being required.
Jan 01, 2011 | Nokia 5800 XpressMusic Smartphone
How to unlock VK Mobile VK2000
i am using rare mobile lg-vx5300 i uk. i tryed many unlocking methods like software,cal.. but not worked finally.. i got my unlock code at www.prounlocking.com.. at reliable cost ... you may also try it.......
Jun 17, 2010 | VK Mobile VK2000 Cellular Phone
I lost my l6 password
dont worry if you have lost your unlock code.
you can use the security code in place of the unlock code.
what you need to do is just press the Menu button (the "-" button just above the ) when it asks you to enter the unlock code.
now it asks you for the security code. if you have not set the security code, just enter 6 zeros. (000000).
if you have changed the security code, just enter it.
now you can set a new unlock code even you dont know rhe old unlock code.
go to settings --> go to security--> goto New Passwords-->select unlock code..
it asks you to enter the old code, just press the menu button, it asks you for the security code, enter it, now enter a new UNLOCK code of 4 Digit.
Hope this helps..
Nov 14, 2009 | Motorola Mobility L6 Cellular Phone
Locked memory card
1.Find unlockMMC.sis and download it from internet.
2.Install it in the phone memory.
3.Run the application and your memorycard password wil be shown.
Mar 29, 2008 | Nokia 6600
Sidekick 3 question
Your phone needs to be unlocked to use the text option. The code it is asking for is the unlock code.
All of the main sidekick features like internet, aim and email won't be available if unlocked and used on a carrier other than t-mobile.
text and calling will once unlocked though.
Jan 09, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Unlock code
Hi melodyanne,
you will be able to find a solution for unlocking your sony ericcson Z310 by logging here http://www.prounlocking.com/unlock-your-phone/rs8wp2/
Oct 28, 2007 | Cell Phones
VK Mobile VK2000 Cellular Phone Logo
42 people viewed this question
Top VK Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a VK Mobile Cell Phone Expert? Answer questions, earn points and help others
