My Amana dryer, model #DLE330RAW is causing problems for me. The clothes are getting caught in the felt around the drum, the corners of shirts and towels are getting caught in the felt that lines the drum just inside the door, causing them to turn black.
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
If you take front of dryer off, there is a half moon shaped piece of felt on top of door opening that most likely has worn and leaves a gap between drum and where that felt is. Replace that for right drum fit.
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Steve
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
This dryer doesn't have rollers at the front of the drum, it uses a felt rub strip between the drum and the front cover. You'll need to replace the rub strip. It's easy to do but you'll need to get the special high-temp adhesive.
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Remove the power to the unit and the bottom access panel. Remove the front bulkhhead where the drum sits on by undoing four screws one for each corner.Verify felt seal on exhaust fan cover is airtight on flange of duct. If seal is installed improperly air flow will be restricted which can cause poor
dryer performance.Belt must be positioned around cylinder between center and rear bafflescrews with the ribbed surface against the cylinder. You gotta push up on the spring loaded idler pulley the easily slip on the belt to the motor shaft. make sure that the ribbed part of the belt wraps around the drum and motor shaft and not kinked.
