Question about Cell Phones
I own a KA08 mini phone keep getting GPRS message
I own a KA08 mini phone and can not connect to the internet or open MMS messages, was adviced to get a TF card and it would solve my problem, but no such luck...Any help would be appreciated.
How to open Globe gprs to Nokia 6303
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Internet Settings
6. Create New Profile
Connect Using: MyGlobe GPRS
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Proxy Address: 203.177.042.214
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
Address: http://www.globe.com.ph/globe.asp
12. Save Changes
MyGlobe Internet Settings
3. Create New Account. GPRS / PS Data
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
1. Go to Menu>Choose Settings>Connectivity
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
My Cect KA08 Mini will not send or recieve MMS Messaging. Also I cant find the internet
you just need to configure the settings manually.
Find AT/T settings here:
http://www.tradebit.com/filedetail.php/8624007
Mar 18, 2010 | Dual Electronics CECT P168 Cellular Phone
Enablig Gprs and MMS of ka08 mini cell phone touchscreen brand
try swapping into the other sim card slot because it did that with me
Feb 16, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
Mini ka08 cannot download mms
Go onto the web browser and see if you are able to access a web page.
An MMS is simply a text message with an attachment. It required access to the data network to fully send. If you are able to access the browser, it is a setting issue. If you are unable to access the browser, it is a data issue.
Contact your provider (AT&T, Verizon, T-Mobile, whomever) for further direction.
Oct 02, 2009 | Apple iPhone 3G Black Smartphone
Mini ka08 gprs not subscribed!!
http://www.youtube.com/watch?v=vSA-CtQeMlk&feature=related
Aug 30, 2009 | Dual Electronics CECT P168 Cellular Phone
I just bought the KA08 mini and can't get internet or mms..
If you have AT&T service or T-Mobile, I have your solution:
T‐mobile
MMS Profile settings 1. server url: http://216.155.174.84/servlets/mms
2. gprs settings: 216.155.165.50
3. port: 8080
4. apn: wap.voicestream.com
5. login: (leave blank)
6. Password: (leave blank)
Browser settings
1. Home url: http://wap.myvoicestream.com
2. bearer: gprs only
3. proxy: enable
4. gprs setting - Gateway
5. ip: 216.155.165.50
6. port: 8080
7. apn: wap.voicestream.com
8. login: (leave blank)
9. password: (leave blank)
i hope this helps you ,,,,,,,also for people with at&t:
AT&T WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1 Select back or done
Select Activate Account MMS Select Messages --> MMS --> Message Settings Select Server Profile Select the first entry Select Edit Profile Edit Rename Profile to whatever name you would like Edit Home Page to http://mmsc.cingular.com Edit Data Account to the same data account you created for WAP Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080 Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE) Edit the Password to CINGULAR1 (UPPERCASE) Select Done or Save Make sure to activate the profile and you are good.
i hope this helps i know how you feel,,been their,, i had to pay for this info on a cd ,,,anything to help
Aug 16, 2009 | Apple iPhone 3G Black Smartphone
KA08 MMS not working
if you go on the sony ericsson site and get the mms settings for a k770i then sony ericsson will send you the settings, i have ka08 and this worked for me. after you install the settings remove the battery and the sim card, wait a couple of minutes and then reinsert them. turn your phone back on and then send yourself a picture and this should work
Jun 28, 2009 | Apple iPhone 3G
Getting "GPRS NOT SUBSCRIBED" message
Data Account Setup:
From the Main Menu select > Services > Data Account > GPRS
Scroll to an empty account (IE: Account icon_cool.gif and select Edit
Set Account Name to T-Mobile Internet
Set APN to internet2.voicestream.com
Leave Username and Password blank
Press Done
Select Yes to Save
WAP Profile Setup:
From the Main Menu select > Services > WAP > Settings
Select Edit Profile
Scroll to an empty profile (IE: Profile icon_cool.gif and select Edit Profile
Set Profile Name to T-Mobile Internet
Set Homepage to http://www.t-mobile.com
Select Data Account > GPRS > T-Mobile Internet
Set Connection Type to HTTP
Leave Proxy blank
Leave Port blank
Press Done
When Prompted to Save select Yes
Scroll to T-Mobile Internet and select Activate Profile
To Access the Browser:
Select Homepage to bring up the homepage
Select Enter Address to browse other pages
To setup Picture Message (MMS)
Create Data Account
Select Menu
Select Services
Select Data Account
Select GPRS
Choose an empty profile
Account Name enter T-Mobile WAP
Press Options
Press Done
APN enter wap.voicestream.com
Press Options
Press Done
User Name
Password
Auth. Type choose Normal
Press Done
Press Save
Create Profile
Select Menu
Select PIM
Select Messages
Select MMS
Select Message Setting
Select a Profile
Select Edit Profile
Select a profile
Choose Edit Profile
Rename Profile enter T-Mobile MMS
Homepage enter http://216.155.174.84/servlets/mms
Press Options
Press Done
Data Account select GPRS
Select T-Mobile WAP
Connection Type select HTTP
Proxy Address enter 216.155.165.050
Port enter 8080
User Name
Password
Press Done
Activate the profile
Jan 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Problems
Nokia Europe - Get settings - Support Get settings. View all Learn how topics ... Multimedia messaging (MMS settings); Mobile browsing (WAP/GPRS settings); Internet access point (Internet ...
europe.nokia.com/A4164073 - 18k - Cached - Similar pages GPRS information and UK settings Information and advice on setting up GPRS on smartphones and mobiles, ... Contact o2 Customer Services to get this enabled. Not available on PAYG ...
www.filesaveas.com/gprs.html - 67k - Cached - Similar pages
Apr 05, 2008 | Nokia 6030 Cellular Phone
Cell Phones Logo
180 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
