Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
How do I take apart the ice/water dispenser? - Frigidaire FRS3R5EMB Side by Side Refrigerator
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
dmftrucker
  • 1922 Answers
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Posted on Aug 23, 2009
milten1
  • 1304 Answers
SOURCE: kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Posted on Oct 26, 2009
Hi How do I stop the water dispenser dripping ?
If you go to www.searsparts.com you can see a parts breakdown, showing how it comes apart. Whirlpool may have the same thing. You can also contact Whirlpool and ask them.
Mar 23, 2015 | Whirlpool Refrigerators
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Jul 31, 2014 | Frigidaire FFSC2323LS 22.6 Cu. Ft....
Ice maker not dispensing
This is possibly only a defective micro-switch on the Dispenser Module. Can you post the model number so I can examine the correct parts?
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 16, 2014 | Refrigerators
Water won't dispense
The part of the=> 2188542 Water Inlet Valve may be defective while you may be getting ice from the ice maker side of the=> 2188542 Water Inlet Valve Let me know iof you have questions, Thanks Sea Breeze Questioins?38124827-761f-4fe9-a92b-e27c07b1020b.jpg
Jan 06, 2014 | Kenmore 57029 Side by Side Refrigerator
I have a Whirlpool refrig./freezer. I have no problem with the ice dropping in the bucket,but when I try to dispense it under the chute,it wil not dispense. The water works fine. This is a side side ...
Sometimes the ice will collect, melt, and freeze into a giant headache. If you have the one where you can get ice out of the holding bin inside the freezer, see if the ice bin will come apart from the rest of the dispenser. If it doesn't come easily, get as much ice out of the bin, get a wet vac ready and pour warm water on the ice. It will run through the dispenser. Once things come apart easily, you can take it over to sink and get rid of the ice blockage with warm water, let it dry, reinstall, and check to see if it works. Hope this helps.
Nov 03, 2013 | Whirlpool 21.8 cu. ft. Side-By-Side...
Water spurts from on top of water dispenser unit
It will need to be taken apart and inspected for obstructions or cracked tubing
Nov 25, 2009 | Frigidaire PHS69EHS
No light on water and ice dispenser not working
there sure seems to be a lot of problems with this GE refrigerator
I will try to find answers soon.
Jul 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenser
Sounds like a control fault on the microswitch to activate the ice and water line. Access to this is immediately behind the ice dispenser section (just above) on the freezer door. Normal access is two screws located behind the removal drip tray section. Either that or the control board for the ice dispenser as you are not getting water as well. Before taking this section apart though you should hear a buzzing sound when you activate the chilled water, if you do then you may have a water supply problem. Hope this helps.
Mar 13, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
159 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
