Question about Excel 3000 Wheelchairs Removable Desk Length Arms, Swing Away Detachable Footrests Medline 3000 Has A Three Position Axle and Push Button Release Rear Wheel
How do I replace an arm rest - Excel 3000 Wheelchairs Removable Desk Length Arms, Swing Away Detachable Footrests Medline 3000 Has A Three Position Axle and Push Button Release Rear Wheel
  • 103 Answers
You will have to contact a dealer in your area for the part. To remove the part there is only two screws on the underside that hold the armrest in place.
Posted on Nov 16, 2009
Need instruction on how to replace the door arm rest on my 2009 Honda accord
Remove screws on old arm rest and replace with new one. Easy straight forward job.
Aug 28, 2017 | Honda Cars & Trucks
How to fit an upgrade armrest on an x type jag?
The center arm rest is attached to the console by 2 small Hex cap screws. The arm rest and intermediate slide panel are attached to the same hinge assembly with rivets.
to replace the upper arm rest, 1st remove the assembly from the console by removing the 2 hex screws this will allow you to work outside of the vehicle on a work bench. 3 rivets hold the arm rest to the hinge. You will need to drill out the rivets using a 1/8" drill bit. and install the replacement arm rest using new 1/8" pop rivets.
see illustration
Feb 07, 2015 | Jaguar X-Type Cars & Trucks
Trying to find the right handed arm rest for Ever med wheelchair, model CBS 89, Serial number: 20013940. Where can I get this part?
depending on the type of arm rest you might have a look on eBay for " wheelchair arm rest" there are several universal types, they are often far cheaper to buy a new pair that to just replace one with original genuine parts.
Dec 16, 2014 | Health & Beauty
I would like to find out how I can order a replacement arm rest
depending on what chair you have the cheapest option is to try and get a generic replacement, search eBay for "wheelchair arm rest" they start from around 10 UK pounds or you might be able to find one from the same make and model.
if not then you need to search the web for the make and model of chair you have followed by "parts arm rest" so if you have a pride jazzy 1121 you would search google for "pride jazzy 1121 parts arm rest" that should point you to a replacment, if no joy there another option is to contact the makers, again search for maker to find contact info, or look for a dealer that sells the make of chair you have.
if this helps please click "yes" to let others know.
Oct 06, 2014 | Health & Beauty
Toyota arm rest on bucket seat removae.
In the down position try pushing real hard into the seat ( as if you were trying squeeze them together.) as you are pulling up on arm rest.
Jul 16, 2014 | 2002 Toyota Sienna
How to remove drivers side inner door trim of toyota camry altise v6 2003
Before you get too carried away it may be possible to replace the arm rest without touching the trim panel. Check for some plugs in the arm rest and if there are some prise them out and you will find screws deep inside that will allow you to remove the arm rest. Normally trim is clipped over the top of the door and held in place by push in clips around the door.
Mar 22, 2013 | Cars & Trucks
I replaced the wiper control module and while I did that the wipers were in the up position. Now the new module is in and they are operating but come to rest in the upright position. Do I need to remove...
Perhaps, you could remove the arms and reset them, but, I am curious, did you replace the 'windshield wiper motor?' I was always taught that if the wiper arms did not come to rest in the right resting place, that the wiper motor was at fault.
Good luck on this repair.
Feb 05, 2011 | 1997 Lincoln Town Car
After replacing the wiper motor and linkage bushings on my Grand Voyager SE, the wiper arms stop in the straight up position when ''at rest''. Help please
Remove the arms,and place them back on where they need to go,do not turn the wipers on,do this as they set now.If the wiper blades when turned on go off the left side of the windshield ,then you will have to remove everything again,and move the wipers down in the rest position,and align everything up to the rest position,with the wipers at rest,and the motor at rest.
Jan 22, 2010 | 1992 Plymouth Grand Voyager
Window Switch Removal - The Drivers window switch has stopped working. How do I get the switch out to repair it or replace it? The window is currently stuck in the down position.
the arm rest containing the control, does come off seperate than the door panel. You will have to be careful when prying it off to avoid damaging the arm rest. There are tabs holding it in place.
It's a fairly simple job, the most aggravating part is pulling the arm rest to avoid bending it or damaging the external finish. Good luck!
Jul 28, 2009 | 2006 Ford F-150
1988 Cadillac Deville drivers window shattered while up
Take the Lights out of the arm rest and you will see more screws.
Dec 09, 2008 | 1988 Cadillac Sedan DeVille
Excel 3000 Wheelchairs Removable Desk Length Arms, Swing Away Detachable Footrests Medline 3000 Has A Three Position Axle and Push Button Release Rear Wheel Logo
85 people viewed this question
Top Excel Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Excel Health and Beauty Expert? Answer questions, earn points and help others
