Question about GENJRS06 Electric Single Oven
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is refrig. the other half is Freezer. I need to find a GE Repair person in my area of Japan with is Hitachi Citt
  • 1,543 Answers
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Posted on Nov 12, 2009
I need top heating element
to be honest cost more usually to fix than buy a new one but your local appliance repair shop is best bet
Jan 17, 2015 | GE Ovens
How do i stop water ciming out of the freezer
check your condensation defrost run off line for blockage. may have to remove the back interior panel of the freezer to access the water catch pan. debris blocking the drain or the defrost line will cause overflow into fridge interior
Jul 03, 2014 | Frigidaire Ovens
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
I have a 1950's GE pink/beige wall mtd w/ matching cooktop...I can't find the model # label on the wall mtd oven ? where is it located ?
Mine is a slightly newer model (1960's pink) and out of the wall at the moment so we looked last night. The nameplate is located just below the opening to the oven, in the center, open the door and look down, riveted on. Maybe yours is there too?
Sep 22, 2010 | GE Ovens
Freezer not freezing on side by side fridge
Try turning the unit off and leaving the door open for half a day or more in case there is ice clogging something somewhere? If there is no cooling going on whatsoever and fan/s and compressor are running it sounds like a gas leak has devaloped or the compressor has stopped working correctly. If the compressor has stopped then possibly the controll circuitry to it has a problem.
Hope this might help
Dec 01, 2009 | Ovens
Maytag Model MTB2154ARW-water is appearing inside on the bottom of the refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 17, 2009 | Maytag CWE5800A Electric Double Oven
NO HEAT OVER 260
Hello red rum,
Yes, have seen this where the oven's thermostat needed to be replaced!
Bless You
Let me know how you are! Please remember to leave a rating before you sign off!
Huuum
Here is an interesting article i just read .
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 22, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Where do i find replacement glass tops for my hotpoint stove? How much do they run????? thanks for the info The glass top has burned, and i cannot remove to burns, can i replace the glass top? and how...
hello Chris700,
welcome.
1.What is the model #
2. How old is the range?
If the range is 6 years old or more it may not be worth spending to much money on it.
Bless you huuum
Here is an article I just read about this matter!
Repair or replace?
When a repair might be a wise choice.
When it pays to replace.
Thank You, HUUUM
Sep 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven low heat
Did you try going to the GE website to pull up the Use and Care Manual? It does have a section re: how to adjust the temperature by as much as 35 degrees either way. Although it is not the 100 degrees you mentioned, you could try it and see if it helps...
The main GE website is: http://www.geappliances.com/
At the top of the web page is a SEARCH section. You can click on the blue down arrow in the first box and select Use & Care Manuals, then put your model number in the empty box to the right of that selection box, ie. JT952 is my oven.
If you are having a problem locating your model number/serial number, you can go to the FAQ (frequently asked questions) section to see how to find it.
Jul 05, 2008 | GE Profile JT952 Electric Double Oven
Refrig not working
what brand is this?? Model#? Is the freezer fan working?? Is the compresor running?? Is there any frost on the back panel in the freezer??
Dec 25, 2007 | Ovens
GENJRS06 Electric Single Oven Logo
105 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
