How do you install a plenum on a trane 4ycy gas pack unit
    President:
  • 1,515 Answers
Hi, The first thing you need is the experience. I can not give you this kind of information over the Internet. Gas packs come in so many different sizes, makes and models, you would have to have the proper tools and know how to install a return/supply air Plenum. Contact you're local wholesale house as they have duct-u-lators to figure the size you will need and they do have prefabbed Units. I would strongly recommend this. Good Luck,
Shastalaker7
Posted on Nov 12, 2009
  • Lineze Schultz
    Lineze Schultz Apr 28, 2016
    Only professional company makes or instal prefab building with fulfilling your requirements athttp://www.afripanels.co.za
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
When the truck is started it causes a vaccuum sucking the injector harness and both gas lines into the upper intake plenum and cause a major air leak. the rubber O ring was changed and it did not stop the...
Than you'll have to pull the plenum back off and see what the problem is. You don't have something mounted correctly. That connector (which is the CPI unit) should hold steady as the intake plenum is installed and be in the correct position after all the bolts are tightened down. If it can fall down below the opening that there is a problem with how the CPI unit is mounted.
Mar 19, 2011 | GMC K1500 Cars & Trucks
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Humidifier was installed on return duct on new trane gas furnace
you are ok. this way humidity will get to whole house if your supply duct splits off. done this way often.
Dec 29, 2008 | Aprilaire 700 Humidifier
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
