Question about Whirlpool Duet GHW9150P Front Load Washer
Belt replace remove back panel yes
  • 30 Answers
You dont need to loosen motor just put the belt on the motor pulley and start on drum pulley and then turn drum pulley. it will slip on
Posted on Nov 12, 2009
    Genius:
  • 1,075 Answers
What is wrong with old belt?remove the top panel also ,make sure the machine has no power to it.switch off all power.when top panel is removed// to the rear of machine you will see the motor under the motor you will see 2/3 nuts and bolts loosen, motor will now move slightly, enough to let old belt off replace with new belt and make sure groves in belt match grooves on wheels.you will need to pull the motor and make sure the belt is tight,tighten bolts and nuts,good luck.adrian;;;;
  • 20 Answers
Yes
Asko T702C Service Manual
That is a pretty easy fix without the manual. Take off the top by removing screws on the back top. Remove the sheet metal screws around the perimeter of the the back panel. Pull the drum off the front enough to drop the belt in front of the drum. Put the back panel back on. Now you can thread the belt back into place. The belt runs with the ridges on the spindle of the motor and on the smooth side on the tensioner.
You should replace the pulley idler when replacing the belt, also. I learned this the hard way and snapped a 5 month old belt.
Jan 19, 2014 | Asko Dryers
My sunbeam 0091 breadmaker does not knead. If I go to 8 which is knead dough cycle it comes makes noise but nothing else.
Yes. Hopefully your machine has a removable bottom panel. remove the panel and get your old belt off and make note of the belt code. It will look something like this: STS 60 S3M471 I sell replacement belts and you can visit me at breadmachineshelp.com
Mar 02, 2013 | Sunbeam 5891 Bread Maker
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
I think the belt is shot. Is this a problem I can
Yes a broken belt you can replace yourself, just remove the back panel loosen the motor bolts and replace the belt then re tighten the motor and make sure that the belt is taught, cost about 20 dollars and will take roughly 30 minutes to repair yourself. Make sure that you unplug the system before you start working on it
May 17, 2010 | Maytag MAH8700A Front Load Washer
Do I enter through the front panel or back panel of the the Maytag MDGT236AWW to replace the dryer belt?
yes you need to access either frt or rear covers to remove the top so you can put repl. belt around drum
Sep 15, 2009 | Dryers
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
121 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
