Question about Canon PIXMA MX850 Multifunction Printer
Canon mx850, when printing an incoming fax I have lines down the page
  • 23 Answers
If the lines also appear when you make copies, it is the cartridge; if not, the lines are coming with the fax image.
Posted on Nov 12, 2009
How do I run a print test page on a Canon Pixma mx850?
Click on Start - Printers and faxes - right click on your printer - Click Properties - then click on Print test Page.
Feb 05, 2015 | Canon Office Equipment & Supplies
Cant enlarge a print. How do I do it on my Pixma mx850 ?
Open the Printer Preferances (control panel - Printers and Faxes - Right Click Canon MX850) Select the page setup from the top tab, and change "printing type" to full page. See Below gmeier_1.jpg
I hope this helps, if so please rate my answer. Thank you for supporting the FixYa Community
Regards GM
Apr 12, 2011 | Office Equipment & Supplies
I have a Canon MX850 and when I print something landscape there is a line down one side of the page....how can I fix this. The line is in the actual image.
Does the line actually look like many little dots? If this is what I think it might be, then it is just the way it is. The machine has little spiked wheels in the paper path to reduce the amount of contact it has with the media, these spiked wheels can get dirty and start having ink stick to them and cause lines. See if you can see the wheels from where the paper comes out and try cleaning them with water dampened Q-tips.
Apr 02, 2010 | Canon PIXMA MX850 multifunction InkJet...
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
How do I print a transmittal report after each fax sent?
Press the Menu button; use the right or left arrows to select device settings. Use the up or down arrows to select Fax Settings. Then TX settings.
Select TX report, then select to print a transmission report after each transmission, then select attach TX image. (This will attach the first page of the fax).
TX report Sets whether to print a transmission report after each transmission.
When Print error only or Print for each TX is selected, specify the following.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Solid wet black line on back of pages
What happens when you print with single sided document selected in the preferences? Is there more than one MX850 printer driver showing in the Printers & Faxes (This is Windows ?? XP ? 95 ? ). If so delete all of them and reinstall. Otherwise I would check a printhead alignment from the Maintenance menu to see if that solves it.
Apr 13, 2009 | Canon PIXMA MX850 Multifunction Printer
Black line
Try wiping the light bar where the page goes in with your finger.
Mar 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Cannot receive auto faxes
This is a known problem with the MX850 - Canon thinks it works, but it needs to be FAX Only when you're out of the office and TEL PRIORITY when you're in the office - then you hit "Hook" when you hear an incoming call as a fax tone. It's a manual answer machine when in TELEPHONE Priority
Mar 18, 2009 | Canon PIXMA MX850 Multifunction Printer
Cannon MX850 Fax Problem
Have you tried telling the printer that it is to be used as "telephone priority"
Press the "fax" button on printer, then "menu" button
Use the left or right arrow keys to key across to "Receive mode settings" then press OK
Use the up or down keys to select receive mode. You should make sure it is in "telephone priority" then press OK
Hope this helps
Dec 04, 2008 | Canon PIXMA MX850 Multifunction Printer
Can not print the incoming fax as well as cannot copy a page
Hi
The scanner unit don't reach the scan possition.If you open the front cover,check and see if the is no obstruction in the scanner parth to flip down to the scan possition.Pull the scanner unit a few times foward down and backwards up.If that dont work the grease on the scanner clutch might cause the scanner not to go to scan possition.For service of that clutch you will have to take it to the Canon dealer.
Nov 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Canon PIXMA MX850 Multifunction Printer Logo
106 people viewed this question
old marine
old marine
