Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Kenmore quietguard 7 dishwasher...clean light flashing, dishwasher won't run repair guy a few weeks ago couldn't come, but told my husband to push a couple of the buttons on the control panel, and it worked for a while... repair guy coming back on Monday, but I''d like to know the buttons to push to reset it so I can use it till then
  • 1073 Answers
SOURCE: dishwasher panel has no power
on some of these there is a fuse it is located on the side of the control board it is a thermal fuse not resetable if it is blown it has to be replaced
Posted on Apr 25, 2008
  • 1073 Answers
SOURCE: Kenmore Quietguard 2
check the water inlet valve first
Posted on May 05, 2008
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
  • 338 Answers
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
  • 58 Answers
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Posted on Jan 09, 2009
Hello, i have a Kenmore Quietguard standard dishwasher. it is in the "lock" position under dry options and the dishwasher will not start. can you tell me how i might be able to re-start this?
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
Jan 04, 2010 | Kenmore Dishwashers
Kenmore 655.13222 k601 bought 5 months ago after
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
Mar 26, 2017 | Kenmore 24 in. 17032 Built-in Dishwasher
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Nov 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
"Heater Circuit Malfunction" Kenmore 16033
Lynn, on the newer boards the key dance is heated dry-normal-heated dry-normal. On the older boards it was high temp-air dry-high temp-air dry. Don't know if yours has been changed or not..Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 16033 Built-in Dishwasher
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
174 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
