Question about Apple iPod MA446LL/A MP3 Player
I have music that plays in itunes,loads to my iPod but will not play The file shows up in the library ,but when I try to play it ,it shows a time bar then goes back to song list
    Problem Solver:
  • 10 Answers
If this problem is on the ipod unfortunatley the way you can try is plugging it in to itunes and click restore which will reflash you ipod to it's original firmware and then update it to the new one and also you song can be deleted int his process so be warned!
Posted on Nov 12, 2009
Hi I have an apple ipod model A1285 I loaded music but i cant play it. The play list shows 0. Can you please assist.
may want to check the library in iTunes to make sure the files are there on your hard drive and on your iPod if the problem persists clear your library and make iTunes find your music in your hard drive again and try placing the music onto the device once more
Jan 06, 2017 | Apple A1285 Nano 8Gb 4Gen Personal Mp3...
How do I delete duplicate songs on my Nano 4gb Ipod? How do I adjust the volume?
Using iTunes' "Show Duplicate Items" feature, you can locate and manually remove duplicate songs on your iTunes music library. Once the library is cleaned, you need only sync iTunes with your iPod to remove duplicates from your device as well. This guide takes iTunes 12 to remove song duplicates.
  1. In iTunes, click "View > Show Duplicate Items" in Music module;
  2. Compare the listed song duplicates upon artist, album, date added, genre, play count, size, bit rate, and more to determine which item to keep and which item to remove;
  3. Hold the "Ctrl" key and click each duplicate you wish to delete.
  4. Connect your iPhone 6 to PC, click your iPhone from the device list, hit "Music" and select "Sync" to sync your library using your existing sync settings.
By doing this, you could delete duplicate songs on iPod from your iTunes. But it will eat a lot time of you. To save your time, let's come to the 2nd method - using 3rd-party iTunes cleaner program.
http://www.leawo.org/tutorial/how-to-remove-song-duplicates-from-an-iphone-6.html
Oct 25, 2010 | Apple iPod nano
Tried to download 50 albums to i tunes library,mp3 files, from dvd by drag and drop. all showing on playlist and also showing all tracks from each album. however none will download to my i pod classic and...
You really should NOT try the "drag and drop" from a DVD - it'll end up making symbolic links ("aliases") to each of the files rather than copying them into the iTunes library. If you click on them in iTunes on your computer WHILE the DVD is mounted they'll probably play, since it can "find" the original files. But your iPod can't "play" them from your DVD, can it? So either COPY all the MP3 files onto your hard drive from the DVD and THEN drag them onto the iTunes "Music" library icon or, instead, in the File menu, select "Add to Library" and select them from there. Oh, and first delete all those dead links with the little grey "x" or question mark by the name in your iTunes music main window to make it easier to tell the new "good" ones you add afterwards (do this with DVD removed).
Mar 25, 2010 | Apple iPod classic MP3 Player
Transfer music from ipod back to library
it is completely possible to use your ipod to transfer music to a new computer.
Now these steps may vary if you have Window's Vista and not Window's XP. However, I will post step by step instructions below each item just in case you are unsure on how to do any of it.
First, on the computer, (without anything else open) click on the start menu and open your control panel. {If you have Vista you will need to click on classic view in the left panel of the control panel when it opens} Then go to Folder Options and click on the View tab at the top of that window, now select Show Hidden Files and Folders. Once that's done go ahead and close out of all windows.
second, you will want to put the ipod into disc mode.
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
After doing this connect your ipod to your computer. If it auto pop's itunes, just wait for the ipod to show up in the devices area and then shut itunes.
Third, open your start menu again, and open My Computer. Once the My computer window is open double click on you ipod icon. Once your ipod opens you will see several folders. You will click and drag the itunes music folder to the new folder created on your desktop. This step may take a while if your ipod is fully loaded. Once complete your music will now be on your computer.
From here, all you will need to do is open itunes. If the music is not auto loaded into itunes, click on File in the top tool bar and open Add Folder To Library. Then browse to the new folder created on your desktop and select it. This will bring the newly added music on the computer into itunes and you will be ready to what ever else you wish to do
Apr 25, 2009 | Apple iPod nano
Ipod sync problems
hi if u have all 1800 songs in your computer folder,,,i advise you to connect the ipod to itunes and reset the ipod for factory settings ,then goto file add folders to library browse folders where all your songs located in your computer click ok
now it sud put all songs in music and then sync it to your ipod completely....if u dont see any !mark in itunes music folder then you are good ...your ipod sud have all 1800 songs.
hope this works for you
harri
Feb 15, 2009 | Apple iPod MA446LL/A MP3 Player
Itunes library wont all sync onto ipod
first the easy part....1800 songs we will not move this one at a time..............plug ipod to pc..open itunes....see on left hand side of screen...pc (music,photo & video folders) and under that ipod (music, photo, video folders)..ok..click on pc (music folder) all your music shows up right ok..this time click & drag the pc (music) down to the ipod music folder and release....its 1800 songs so lets wait til the ipod is finish (look at the ipod file a circular motion is happening,,,,its loading).......once finish always eject your ipod...............now find where you are storing mp3 / mp4 on your pc...once you find it ..go to top bar view then click,on view details (artist,album,type,lenght) this where it will say mp3/4/wma/wav or flac file
My ipod/ itunes music
Hi Relothegoon
im not sure how to resolve this problem but i know a few things you can try ^-^
ok the icon your computer shows is normal cause when you buy music on itunes its a protected .m4p file, *just to clear that up so you won't worry ^-^*
maybe your ipod is set to auto sync with only the checked songs in your itunes library, you can change that in the ipod screen that shows up when you connect your ipod,
if that doesn't work then maybe your computer was somehow deauthorized to play purchased content from your account, in that case in the drop down menus at the top is one labeled "Store" and in that drop down menu should be a option thats labeled "Authorize Computer"
Jul 27, 2008 | Apple iPod touch
My ipod wont play any music
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
After that a restore
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your itunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of itunes.
  • 2. Open itunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in itunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main itunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt itunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, itunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the itunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
If the problem still isn't fixed take it back to the shop for a replacement.
Jul 04, 2008 | Apple iPod nano
Loading My ITunes library into new Sansa Clip
Hey guyi,
According to information provided by the manufacturer (Sandisk), the Sansa Clip MP3 player can use two different methods to upload songs: a simple drag-and-drop interface, or syncronizing the player with Windows Media Player.
With the traditional drag-and-drop interface, you would need to connect the player to your computer and select the "Open device to view files using Windows Explorer" option when it is presented. Once you have done this, you should be able to double-click on the "Sansa" player and then the "Music" folder. After this folder has been opened, you should be able to drag and drop (or copy/paste) the files into this folder to upload them to the player.
For more information or instructions on how to add files to your Sansa music library using Windows Media Player however, you may wish to refer to your owner's manual or the following link on the manufacturer's website:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
Unfortunately Windows Media Player does not currently appear to support the ability to directly import iPod playlists, but if you keep most of your music files in the same folder/directory on your computer, both programs should be able to share the same music library. Please keep in mind that this may only apply to music that you loaded onto the computer yourself and other unprotected file formats that both programs recongize (like .MP3 files), and may not necessarily apply to copy-protected songs downloaded from iTunes or other online music services.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 06, 2008 | Audio Players & Recorders
Ipod to pc music play
You can only transfer music from an ipod to a computer if they were purchased through itunes.
If that's the case, right click on your ipod's name under devices. Then click Transfer music.
Dec 24, 2007 | Apple iPod shuffle MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
47 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
