Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Have changed drum cartridge and still has trouble printing colour. Very washed out. Have run cleaning/maintenance feature, does not show any error messages. Runs as normal except for poor quality colour. Hope you can help!
  • civicvideoja Nov 29, 2009
    Hi there and thanks for your interest.
    I followed your instructions but unfortunately the printer is still playing up. Black is printing perfectly, colour is very washed out and getting worse. Any other ideas? Thanks :)
    President:
  • 1,462 Answers
Check whether the exposure adjusted correctly?
CHeck increasing the exposure and try printing and check whether you have the correct prints.
CHeck whether the machine is not set to toner save mode?
Set <B&W TONER SAVER> to <OFF> in <COMMON SETTINGS> of the menu
PLease leave me comment, if the above solution fails
RNj VINOVKUMAR
Posted on Nov 12, 2009
There are no signs of error but the paper comes out blank
Hi Zanda
if you haven't used your printer for that long, your printhead is more than likely dried up and clogged. Try running the "Head cleaning" utility 2-3 then print a "Nozzle check" (find both of these functions on "Maintenance" page under "Printer properties".
If the nozzle check shows any print, you're on the right track. Run few more head cleans or try printing several pages (with LOT of colour) on high (best photo) quality. Combination of printing & nozzle checks works best. Be prepared to waste lot of ink doing this!
If you get no print at all, it's probably time to get a new printer. There are other things you can try eg. buy set of cleaning cartridges, try to clean the printhead by placing some folded tissue soaked with Windex under the printhead or forcing some Windex through the printhead pickup (using a syringe & rubber tubing fitted over the pickup needle - where the cartridge usually sits) etc.
Another way yet is to remove the printhead from printer and soak it in cleaning solution (if if you're handy and prepared to pull your printer apart).
good luck!
Lumir
www.inkbank.com.au
REFILLABLE CARTRIDGES
Mar 02, 2014 | Epson Stylus RX425 Multifunction...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
My machine says Drum Error, refer to trouble shooting for maintenance?
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
Open the front cover
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Feb 03, 2011 | Brother MFC-7340 All-In-One Laser Printer
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
I have used my iP1300 with no problem until it ran out of ink and now the red is very orange and the whole page is faded. I have run a head clean, is there anything else I can do?
Hi - try this. Get cartridges into centre of printer - turn power off by pulling the power lead out. - (dont press power button as cartridge may head back inside - a no no.)
Remove all cartridges, then remove print head by lifting the arm to the right of the printhead. Carefully blot dry all ink showing top and bottom of the printhead with a lint free 'paper" - the stuff they make baby wipes out of is ok as it does not fall apart as does paper tissue.
Wash the print head under warm very clean running water until all colour stops running from top and bottom. Blot dry from time to time to check the clolour is finished. When it is so, make sure all of cartridge is DRY then replace in cartridge holder and close right arm down.
Replace ink cartridges, close top lid and power on again. You should check you cartridges are the correct colour ie not purple or orange etc before reinserting them - else you will have the problem again.
Go into maintenance mode and run cleaning on all colours - this will flush ink thru all heads. Do a nozzle check and it should be all pretty good.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Stopped printing in colour
If you don't use the color on a fairly regular basis (once a day), the cartridge tends to dry out and plug up. You can try and wipe the cartridge outlets with a damp cloth or even use a little alcohol, and run the cleaning feature several times, but may well have to just replace the cartridge.
Feb 05, 2008 | Dell A920 InkJet Printer
Print cartridge error
Press either the menu or setup button.
There should be a maintenance section where you can do eletronic print cartridge cleaning and print head alignments and calabrations.
Some of them can be done at the computer if you access the driver properties.
You can clich the print queue and look around there also for print head cleaning and some other diagnostic procedures.
If those don't resolve the problem, remove the cartridge and take a fuzzless cloth dampened very slightly with alcohol and clean the contacts to the print cartridge.
PLEASE REMOVE THE POWER when cleaning though.
Dec 20, 2007 | HP PSC 1315 All-In-One InkJet Printer
Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Dec 16, 2007 | HP DeskJet 5150 InkJet Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
old marine
old marine
