Question about Motorola Mobility W490 Cellular Phone
I can't get the Micro SD card to go into the slot. I put it in there and wait to hear a click, but the only sound it makes is a grinding like I am tearing up the card. Help please
Micro sd card wont click into place garmin nuvi 2589
On some units, they won't click. You slide the micro SD card into the slot and you will feel a slight resistance. Continue to slide the card in until it stops. It will only slide in one way. This is exactly how the micro SD card slides into a standard SD adapter. There is no click. If you connect the GPS to a PC using the USB data cable, your PC should recognize (2) memory devices; (1) The GPS and (2) the SD card. It may take a few moments. Wait a few minutes until you see both appear in Windows. Always select EJECT or SAFELY REMOVE before you remove the USB data cable.
Feb 28, 2016 | Garmin nuvi 2589LMT 5" GPS with Built-In...
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
How do you put your micro sd card in the computer?
if theres a slot for an sd card on your computer you need a micro sd card adapter. if it doesnt have an sd card slot you need to buy a usb memory card reader (making sure it takes a micro sd card first)
both are widely available in supermarkets/electrical outlets or on ebay/amazon/play etc and are very inexpensive.
(micro sd adapter)
(memory card reader)
Aug 02, 2011 | Kingston 4GB Secure Digital High Capacity...
I just bought the DANE-ELEC Micro SD. It comes with the Micro Card and the USB and the SD Adapter. I am trying to get the pictures from my phone to my computer. There are no instructions so I do not...
Put the Micro SD card into your phone and transfer the pictures to it. Once you have transferred the pictures, take the card out of your phone and put it into the SD Adapter and then into the USB Adapter. Once you have done that plug the USB Adapter into your computer and wait for it to load. After waiting a few seconds, click start, my computer, then double click on the SD card icon. Your pictures should load and you should be able to transfer them to your computer.
Jul 29, 2011 | Computers & Internet
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
The micro sd card keep popping out
may be you put it in the wrong way.
May 14, 2010 | Cell Phones
I have alot of photos in my pc and wanted to put this 2gb card and get them on there
put the microSD into a micro SD adapter and plug the adapter into the SD slot on your PC the folder will open and you can drag photos from your photo folder into the SD folder
Oct 01, 2009 | PNY 2GB microSD Memory Card
I put my sandisk into the front of my computer, and my computer hasn't yet recognized it. How do I access my pictures?
As stupid as this sounds, make sure the micro SD is in the correct slot and fits snugly. If you find that you don't actually have a micro-sd slot, you can purchase a piece that the micro-sd goes into creating a disk that's SD size.
If that's not the problem, go to Start > Computer > and look for the removable storage device. If it shows up, dbl click on it and see if your pictures come up.
If that doesn't work, you may consider buying an external card reader that connects using a USB port on your computer. That should work. If not, there is a strong possibility your micro-sd is corrupted.
Sep 05, 2009 | SanDisk 2GB microSD Memory Card
HOW CAN I upload music on the LG KF 310
using data cables,blue tooth,for best music download see on www.mobile9.com
Jul 06, 2009 | LG KF310 Cellular Phone
Laptop
are u sure that the SD card fits in the slot perfectly and doesnt come out?which SD card is it,is it a MINI SD or MICRO SD? because for these two u must use SD CARD ADAPTER.. only then the card will sfit in perfectly. Also when it is inserted properly and it fits in then u will hear a DING sound in ur laptop whether ur running VISTA,XP or ne other OS and also u can see the Memory card as the "name" of the card or as "REMOVABLE DISK" in "MY COMPUTER".Please confirm me with this step and ill help u out furthur.
Oct 04, 2008 | HP Pavilion dv6000z Notebook
Motorola Mobility W490 Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
