Question about Kenmore 64742 Electric Dryer
My kenmore dryer just quit, there is power too it but it will not startnot sure if the timer is shot or the start button
  • 464 Answers
On a lot of the Kenmore dryers, if the drum belt breaks the dryer will not start. So check the belt.
Posted on Nov 12, 2009
My Kenmore Dryer just quit today. I have checked the breakers. They are ok.
Many possibilities. Door switch, start switch, timer, thermal fuse, motor, belt, or improper voltage I think mostly covers it.
Oct 12, 2017 | Kenmore Dryers
I have a Kenmore 70 Series dryer that started up then after a few minutes it quit altogether. Power is there, timer doesn't tick anymore like it used to (when you close the door but don't push the start...
Check for continuity of the thermal fuse located in the back next to the cycling thermostat (its white) You also need to make sure your breaker hasn't tripped or partially tripped. Try turning the breaker all the way off then back on. If those things are ok your next step is to check to make sure the belt isn't broken.
Jan 11, 2011 | Kenmore Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Kenmore dryer quit running. I don't hear the timer moving and motor is not moving the tub. I've checked the circuit breakers and they are not tripped. I've even reset them. I'm about to check the...
heatman101
Sep 04, 2010 | Kenmore Dryers
My dryer won't turn on (start button?) The timer works though. It quit working in the middle of a cycle and I'm pretty sure the heat was still working, it just stopped working.
Sound`s like a broken drum belt. When the belt break`s on most kenmore/whirlpool dryer`s it prevent`s the unit from starting via a ``kill switch`` located under or next to the belt tensioner/idler pulley.
Since you`ve indicated the timer appear`s to advance/work, it is not the thermal fuse/cut-out.
The other possible fault is in the start button, but that is not very common.
I`d look at the belt. That`s what I`d check first. Hope that help`s.
Good luck and thank`s for visiting fixya.
macmarkus :)
Dec 13, 2009 | Kenmore Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Kenmore 64742 Electric Dryer Logo
202 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
