ICODE C-620 I"m getting A c-620 code on my copystar cs-1810 what do I need to do to fix this . I just got this copyer so I don't konw alot about it.
  • 610 Answers
C-620 is a fuser low temperature error (not heating up to proper temp). need a service call to figure out if it is the heat lamp or thermistor that has failed.
Posted on Nov 12, 2009
Testimonial: "thank you for the input. I"ll go a head and call a service person to fix it"
I got the code c610 on my copystar cs-1810, how to fix, and where i can get the manual as well
Broken fixing heater wire
? It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
Fixing unit thermistor installed incorrectly.
Check and reinstall if necessary.
? It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
? It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Fixing unit thermostat triggered.
Check for continuity. If none, replace the fixing unit thermostat.
May 08, 2011 | Copystar CS-1810 Copier
Copystar CS1810 shows error code J00. How do I fix this?
J00 means that the machine did not pick. remove the cassette and the put back and press start again
Feb 15, 2011 | Copystar CS-1810 Copier
Instruction how to operate CS-1810 copystar printer
Go to Kyocera in your country.Most manuals are available on line free.
Jun 12, 2010 | Copystar CS-1810 Copier
Copystar CS-1810 copier- what does A 400 mean?
that means your laser unit is not spinning up to speed. sometimes, you can fix by pulling laser unit and removing the polygon lens/mirror, then putting a small drop of lube on shaft and re-assembling. other times, you have to replace laser unit. thats quite expensive.
hth,
razors
Mar 16, 2010 | Copystar CS-1810 Copier
Hi I have a copystar CS 1810 and it started to make a loud clicking noise and now I have a code showing on the display 620 and C. Can you help Thank you, John
Hello sir; It's a fuser problem, but you need to reset, the procedure as follow; Press and holding down following keys in order, "stop/reset", "start", and "left copy density", then press "stop/reset" key again, then enter U63 press "start", window will display "CLE", press start again to clear.
Oct 27, 2009 | Copystar CS-1810 Copier
Copystar 1810 document feeder slips grinding noice
Sorry Mike,
No spare parts are available.
Jun 27, 2009 | Copystar CS-1810 Copier
Code e70 on copystar 1810
Jam code 70 means: No origional feed. Paper is detected on the doc feedr tray, but when the start button is pushed - the origional don't feed through.
Mar 12, 2009 | Copystar CS-1810 Copier
COPYSTAR CS-1810
Hello sir; "AP" isn't a problem, just let it run for a little while, it will disappear.
Feb 18, 2009 | Copystar CS-1810 Copier
Copystar CS-1810
You need to run sim U163 to reset fixing heater problems. Press and hold stop, start, and left exposure key in that order. Release and press stop again. Use zoom keys to enter 163, press start. Exit the mode by entering 001 and start, or power off/on.
Jul 21, 2008 | Copystar CS-1810 Copier
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
59 people viewed this question
jasbo
jasbo
