Question about Dynex DX-E401 Router
Dynex router won't communicate with the modem.
I have had this router for about a year working fine but suddenly this dynex router won't communicate with the modem. It will issue an IP address but won't allow internet access. The router doesn't see the modem.
  • 2,263 Answers
If you connect the modem to the computer, does it go online ?
If your computer is online through the modem, then the modem is working properly.
Check the connections between the modem and the router.
Reset the router for 30 seconds , unplug the power to the router and plug it back in. Wait for 1 minute and set up the router again manually.
Click Here for more info
Posted on Nov 12, 2009
Hi. I have a Motorola SB 6121 DOCSIS 3.0 cable modem. When I have a direct connectivity with this modem to the laptop with an ethernet, it works fine. But when I connect it to the Linksys wireless router,...
what is the ip address of the cable modem ?
when connected directly to the modem can you do ipconfig in dos command window and find out the gateway ip address listed.
This has to be the gateway ip address in the wi fi router.
turn of DCHP server in the WI FI router and make its ip address one more than the cable modem ip address.
make sure subnet mask is the same in both devices
Make sure DHCP server in Modem has leases above 20 to allow other devices to use 1 - 19 .
eg 10.0.0.1 or 192.168.0.1 for cable modem ip address internally.
make wi fi router 10.0.0.2 or 192.168.0.2 depends on the ip address of modem ?
Gateway address of 10.0.0.1 or 192.168.0.1 depends on the ip address of modem ?
dhcp server leases from 10.0.0.21 to 10.0.0.254 depends on ip address of modem ?
Feb 22, 2018 | Computers & Internet
I have just bought a Dynex [DX-E402] router and i'm trying to connect my laptop and pc to the same internet through it but its not picking up any internet access. If i connect my pc directly from my...
The modem has likely assigned it's IP address to the MAC address of the PC.
We need it to assign an IP address to the WAN port MAC address of the router!
When you hook up the router, the modem is no longer sending data to the correct MAC address.
Unplug the power to both the modem and the router.
Power up the router FIRST, and wait for it to complete it's initialization.
Once the lights have settled down on the router, power up the modem.
Wait for it to fully initialize.
NOW turn on your PC or laptop, and everything should be working just fine.
If not, post a reply or add a comment to this post, and I will try to further assist you.
Jun 24, 2011 | Dynex DX-E401 Router
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Dec 29, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
I'm trying isolate parts of my network and I need to place a Dynex 4-port router right after my modem and then plug my office lynksys router into that. (At present, the linksys is plugged into the modem...
Modem <--> Dynex <--> your computer should work.
Connect:
Modem <--> Dynex <--> Linksys router <--> your computer.
Turn off all the above devices.
Turn the modem on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Dynex on, and wait for its lights to "settle" down to a repeatable pattern.
Turn the Linksys on, and wait for its lights to "settle" down to a repeatable pattern.
Turn your computer on, and wait for its lights to "settle" down to a repeatable pattern.
On your computer, click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
The Linksys router should have given you an IP-address for your computer, and the IP-address for the "gateway" (namely the Linksys router).
Start your web-browser.
Type http://192.168.0.1 (or http://192.168.1.1) to connect to the web-interface "inside" the router.
Access the 'WAN' settings-page on the router, to see what IP-address the Dynex router has given to the Linksys router, and what "gateway" IP-address that the Dynex router has offered to the Linksys router.
It might be best to change the range of "dynamic" IP-addresses that one of the routers hands out, e.g., '192.168.123.100' to '192.168.123.200' for the Dynex router, so that both routers don't try to hand-out IP-addresses in the *SAME* range.
Apr 05, 2010 | Dynex 4-Port Ethernet Broadband Router...
Connect MSI RG54G2 to speadstream 4200
so that means if you connect the computer to the modem, it works but not with the router.
it seems that the router and the modem are not communicating with each other.
When you connect the computer to the modem , check the IP address through the modem. If ti is private IP address then you will need to change the settigns on the router.
Click Here for more info about networking
Oct 14, 2009 | MSI RG54G2 Router (MS-6848-002)
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Dynex 4 port hub xbox 360 IP address error
Here is a link to their Support site: http://support.xbox.com/support/en/us/nxe/default.aspx Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Dynex dx-ehb4 will not change ip addresses
I am not familiar with that router so I will provide general knowledge and you can apply it to fix your problem.
It sounds like your cable modem is willing to supply a single IP address. This can and should be connected to the WAN port of your router. The problem is that the router is not assigning IP addresses to the equipment that is connected to its LAN ports. Instead, it allows that single cable modem IP to be assigned to connection #1 and everybody else gets nothing. Get the computer working through it, connect to the router as per the owners manual and turn on NAT or DHCP, whichever it offers. Reboot the computer and connect xbox and you should be good. This was probably not an issue with DSL because your DSL modem would supply up to about 10 IP addresses and they also passed through the router.
Mar 03, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
My Dynex 4 port router will not communicate with my DSL modem
Have your router clone the MAC Address of your computer. The MAC address is a hardware address on your network card and DSL providers seem to like to bind it to account. What is probably happening is when the router connects to your ISP and asks for an IP address, it looks up your account info and and decides - nope, wrong device. Cloning the MAC address will make them happy. If you are not able to clone the address, call your provider's tech support and ask them to clear the MAC address from your account. Make sure you have the router plugged into the modem and not the computer or you are back to where you started.
Jan 05, 2009 | Dynex 4-Port Ethernet Broadband Router...
Establishing a Network Connection
First whether the connection is pinging or not if pinging means its working may be the ip address problem
Feb 14, 2008 | Computers & Internet
Computers & Internet Logo
224 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
