I have a Glow Warm stove that will not stay lit after i release the igniter switch...
  • 8,220 Answers
If the safety device gets a bit of lint or dust in it over the warmer months when it is not in use then thatwill constrict the safety feature and make it thank it is low oxygen in the room. Blow out the pilot safety device.
Read MORE HERE
Posted on Nov 12, 2009
Testimonial: "THANK YOU SO MUCH!! IT WORKS NOW"
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
How do I keep my gas fire pit lit?
My guess is hold in the button for 30 seconds and the slowly release the button. The thermocouple has to first warm up before you release the knob. Remember wait and then release slowly. Just a guess.
Nov 28, 2014 | Woodard Outdoor Cast Aluminum 42 Square...
Avanti G2002CW oven or broiler won't stay lit once ignited
I had this same issue on this same model (which is how I happened upon this page). I'm still not exactly sure why, but the problem resolved when I pushed down on the knob more firmly than I normally would to light the stove, and it seemed to slide in a little deeper. After that, the oven would light.
Jul 07, 2013 | Avanti Kitchen Ranges
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
The oven will not work, stove top works fine
Try starting the oven...open the broiler door and look to the rear of the broiler..you should see a reddish glow occurring...if not, then the igniter may have become defective...if it is a standing pilot stove then you need to make sure pilot is lit...if it won't stay lit, then the thermocouple may be defective..either way, these components are available at appliance parts store's or on the i-net
Dec 21, 2010 | Whirlpool Kitchen Ranges
1997 VW JETTA DIESEL GLOW PLUGS
The glow plug relay is responsible for the duration of glow plugs, this needs to be the starting point. You should get a 12v out for so many seconds when ignition is switched on.
I have taken the cover off relays in the past, cleaned up the internals, sprayed with circuit cleaner and got plenty more years out of them, worth a try.
Nov 21, 2009 | 1997 Volkswagen Jetta
Glo-Warm Model #WMN20 20,000btu. Can hold down and ignite the pilot but as soon as i let go the pilot goes out and with out igniting the unit.
WITH THE HEATER OFF, clean the pilot flame unit with a can of compressed air. Blow directly into flame hole then try it again. if it continues to "not" stay lit then you need a new thermocouple.
Oct 27, 2009 | Desa International Blower Glow Warm Wall...
WE can get the pilot light lit but it will not stay on
You will need to check the pressure regulator for the gas.
It sounds like the gas pressure is to low to keep the pilot lit.
John
Oct 01, 2009 | Desa International Blower Glow Warm Wall...
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
94 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
