Question about Amana ABB1927DE Bottom Freezer Refrigerator
Rust on outside of freezer door -- is there an epoxy or white coating to cover over the rust?
  • 3,600 Answers
You can clean off using a green scrubbing bad and some brasso all at wall mart then buy a can of spraypanit and spray it with food grade paint by Krylon paints also at wal mart. The paint will seal it and keep it from comming off.
Posted on Nov 12, 2009
Testimonial: "Thanks for your speedy response!"
    Top Expert:
  • Amana Master
  • 12,650 Answers
You can buy an appliance paint or if u want buy an epoxy paint either one available at most stores that sell spray paint
My water pan is corroded. What can I use to recoat the pan? Do I sand down to base material then prime then coat?
Sand off all the corrosion to bare metal. Use a metal etch to scrub it down (any phosphoric acid will do), this can be gotten at Home depot or any home center in the paint section (also know as naval jelly). Clean the area with clean water after applying the acid and let dry. The naval jelly will leave a slight coating after the rinsing and this will prevent rusting afterward. Prime the metal with automotive primer, 2 or 3 coats will do. Let each coat dry completely. Use an epoxy paint (I've used single stage polyurethane and 2 part mixable epoxy type). The 2 part mixable epoxy is more expensive but lasts indefinitely and gets very hard). McMaster-Carr Supply has these products and they can be ordered on line. Apply the paint, let it dry according to the manufacturers directions and you shouldn't have any problems.
Apr 12, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My husband and I painted our garage last night with the Epoxy Shield. We used the 2.5 garage floor kit. Our problem was we did one can at a time instead of mixing all together. The cans were off in the...
You're probably already done with your project by now, but you should wait at least 24 hours, lightly sand, and wipe surface with acetone and a microfiber towel before applying a second coat.
Aug 24, 2013 | Rustoleum Rust-Oleum Epoxy Shield...
Freezer does not freeze anymore
the freezer usually has the condensor coil sandwiched ilong the outer cabnet and in the back the lines come out in to the compressor compartment as a tech i have found the steel line rusts where the epoxy coating is no longer in tact so i would say you most likely have leaked out the refrigerant
Feb 10, 2013 | Freezers
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Feb 10, 2012 | GE Microwave Ovens
My oven sparks from the metal plate on the side.
Check to see if there is any rust or cracks in the coating that came from the factory. Some microwaves use metal underneath an epoxy type coating and if it is exposed, it can cause an arc from the microwave generator. If there are any defects in the surface, it can be sanded down and you can purchase a can of interior microwave paint and put a coat of paint over the defective area. Also look for any exposed metal in the area of the sparks, there should no metal exsposed anywhere, if it is, cover it with the paint. hope this helps.
Feb 13, 2011 | GE Profile Spacemaker Over-the-Range...
Door on freezer appears to have rust pittiing spots
fridge/freezers are only painted on the OUTSIDE,the interior has only got primer,so if kept in a garage or any high humdity area rust will occur.(from the inside out,like a car)NO CURE......thats the way makers get you to buy new.....
Oct 03, 2010 | Whirlpool Refrigerators
Ice flap door won't close - Freezer and ice maker frost up
Every time you use the ice dispensor , when the flap opens , cold air will fall inside the enclosed dispensor cover . This cold air , mixed with the warm outside air , produces moisture inside the cover . After so long , this moisture starts turning to rust , causing the solenoid and plunger to rust . G E has no "fix" for this problem yet . My suggestion , would be to drill holes in the bottom of the dispensor enclosure (white plastic enclosure , held on by 4 screws ) at certain points , so that the cold air will fall thru the cover , instead of staying in the enclosure . This is something I have to try on customers refrigerators for a while , before I send this Idea to G E . To answer your question , yes , I is normal to replace every couple of years ,.....for now anyway .
Sep 11, 2009 | GE Refrigerators
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Jun 11, 2008 | Jenn-Air JCD2389G Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
517 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
