Question about HP Officejet 5510 All-In-One Thermal Printer
My printer says "needs paper" but i keep putting paper and it has the same response. what do i do?
    Genius:
  • 2,785 Answers
Plz send your printer for servicing
Posted on Nov 12, 2009
When I try to pring something--letter or envelopes, it tries to bring through several sheets at a time.
The pad that is responsible for separating the paper has likely worn out and needs to be replaced. You can order and install a new pad without sending the printer out for repair. It is also possible that the paper is wet due to humidity. Make sure the paper is properly stored and that it is "fanned" before putting it into the printer.
Jan 10, 2011 | Office Equipment & Supplies
Tip
The Printer picks up multiple paper from the manual feed tray?
The reason is as follows:-- The pad that is responsible for separating the paper has likely worn out and needs to be replaced. The pad is located in the printer where the end of the paper reaches in the tray.You can order and install a new pad without sending the printer out for repair. It is also possible that the paper is wet due to humidity. Make sure the paper is properly stored and that it is “fanned” before putting it into the printer. this will help.good luck.
on Mar 05, 2010 | Office Equipment & Supplies
The paper keeps on jamming now and/or coming out the back end of printer. I'm using the correct HP paper? What can I do?
Remove the back cover from back of printer. (by holding notch and pressing to the right side then pulling)
The part removed is responsible for directing paper to the top. Clean rollers by as applying a lighly damped lint free cloth and check if every roller is turning by finger.
Now, put back the cover by inserting the right side first and push.
Good luck
Nov 29, 2010 | HP PSC 1610v All-in-One Printer
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
4355 papar jam error solution
THE PRINTERS MANUFACTURED BY HP ARE HAVING THIS PROBLEM IN COMMON ALL THE WAY. WE SHOULD TAKE FOLLOWING PRISCPRIPTIONS WHILE RUNNING THESE PRINTERS
1. LOAD PAPERS AT SOME DISTANCE FROM THE PAPER LIFTER THAT MEANS KEEP THE PAPERS SOMEWHAT BEHING YOU KEEP THEM
2. WHEN THE PRINTERS ARE OLD THEM GET THEIR PAPER LIFTER CHECKED AND TRY TO PRINT ONE PAPER AT A TIME.
THANKS
PROUD TO BE AN INDIAN
KAMAL DEV JHALLI
HAVE A GOOD DAY
Nov 25, 2009 | HP Officejet 4355 All-In-One InkJet...
Error response: out of paper
Did you press "ok" or "start" after you reloaded the paper? If so, turn off the printer, unplug it from the power source for a few minutes and then plug back in and turn it on again. That should help.
Jun 21, 2009 | HP Deskjet 3845 InkJet Printer
Back cover open message
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
Sep 02, 2008 | Brother MFC-7820N Printer
Setting up fax to send or recieve..just ringing, showing busy no response
Hi! I not computer smart nor am I an expert, but try this. I just got my machine.
put the phone jack into the wall to your printer. Put the paper on top to feeder the paper will come out at the very top
next, dial the number using area code, then press either ok or start
Good Luck, I do hope that works.
If it doesn't call dell supporters, they will walk you through it.
mamalong2000@yahoo.com
Mar 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Problem with Dell 725 Printer
We have the same problem. It seems to help if you load a lot of paper
Oct 07, 2007 | Dell 725 InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
Seeker5211
Seeker5211
