Question about Humidifiers
Mold in Tubing?
Is the tubing on the humidifier look like it has "white mold" growing in the tubing?
  • 111 Answers
Use Citric acid mixed with hot water to remove the mold, it is found in the cooking Isle of most shopping center, EG Woolworths, IGA ect ect
Posted on Nov 12, 2009
Mold in the machine. how do I clean and disinfect it?
The best way to get rid of the mold is to use bleach water. You need to clean and scrub it out, making sure the bleach gets in every cranny. Lastly, really (and I mean really) rinse it out. I would suggest washing it out several times to be careful.
Elisa Jed ' http://www.colfaxcorp.net/services.html
Apr 06, 2014 | Venta Airwasher VS 207 3.7 Gallon...
Is mold ever a problem with this unit
As far as I'm concerned mold is always a potential problem with any humidifier. You can buy a cleaning solution at most hvac supply outlets that will keep this to a minimum and also smells good. If you want to do it for less money and don't mind the smell of chlorine then use 3-4 ounces monthly to control mold and bacteria growth. Thank you.
Feb 05, 2011 | General Filters 1099-LH Humidifier
The clear plastic drainage tube that runs from our Aprilaire furnace humidifier into the basement floor appears to be clogged with brown gunk. How can we clear this line.
One way of removing the gunk is to disconnect the tubing from the humidifier and use a flexible and thin rod that will fit in the tubing and try to dislodge it, or you can try using a shop vac and see if the suction pressure will remove it. If the tubing is really clogged then sometimes it's better to just replace the vinyl tubing with pvc pipe and drain it to the floor drain, I always prever pvc pipe over vinyl tubing when it comes to drain lines for humidifiers.
Jan 17, 2011 | Aprilaire 700 Humidifier
Cleaning internal humidifier
Try using vinegar and distilled water.
If this does not work try using a little bleach and water. Repeat till mildew is gone.
Rinse thoroughly Again & Again.
Everyday humidifiers should be cleaned.
After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
Mold & mildew will cause you to get very sick.
If the mildew does not go away replace your unit.
May 19, 2010 | Humidifiers
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
Why does so much scum and mold develop in the water tray and on the filter ?
Mold and algea form in the tray and filter of drum style humidifiers because humidifiers are a warm damp place, perfect breeding grounds! I suggest updating to a drain through style humdifier, as it does not allow water to sit stagnent in a tray. Hope this helps
Jan 21, 2010 | Humidifiers
How to clean a moldy humidifer?
Bleach is a good way to clean a mold humidifier or you can buy additive expecially made for humidifiers to fight mold.
Dec 20, 2009 | Humidifiers
I have discovered mold growing inside the chamber that mist emits from. how do i thoroughly clean it. how often should i clean it?
The best thing around your house is bleach, it kills mold dead. Mold needs moisture, food, air so removing any one of those will kill it. I would try cleaning with soap and water with a little bleach every two weeks and see how it goes, they increase or decrease the time between cleanings as determined necessary. Remmeber bleach stains anything it comes in contact so be careful with it.
Good Luck,
Gilshultz
Dec 01, 2009 | Vicks V4500 1 Gallon Humidifier
How do I take the hose apart to clean it because it has mold in it?
just replace the hose. its 1/2 vinyl tubing you can get the required length at any hardware store and a hose clamp to support to bottom of he humidifier
Aug 24, 2009 | Aprilaire 550 Humidifier
How do i clean the mold off my humidifier?
Fill it to with in an inch of full, add two tablespoons of clorox and fill it the rest of the way. Run it for a few minutes and then just let it sit over night. The next day empty it out and refill it with fresh water and one teaspoon of clorox. You will be good to go.
Apr 02, 2009 | Duracraft DWM-250 2.5 Gallon Humidifier
Humidifiers Logo
165 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
