Question about Plumbing
How to replace the bath tub pop up handle-thanks
  • 119 Answers
Lever handle you can buy replacement plates at most home improvement and hardware stores and connect the existing linkage to it
Posted on Nov 15, 2009
Moen Shower Valve Model L82839 installed: Water comes out of shower head when running bath. Thanks.
Only two possibilities here the diverter tub spout is not open all the way to let water to the tub only or the shower valve is installed up-side-down.
http://www.moen.com/shared/pdf/l82691pt.pdf
Mar 06, 2011 | Moen & Posi-Temp Single Handle Shower Or...
I have been told there is a way to adjust bath tap temperature under the bath is this true? Thanks
is this a standard bath tub?? if so the answer is no only pressure from hot/cold usually thru the access panel other wise you will have to crank up the water heater unless you have an on-demand water heater located near your access panel. which raises a second question. your faucet? is it a single handle for both hot/cold or two individual handles? if its a single handle try opening up your hot water valve in the access panel to allow for more hot water flow and slightly decresing your cold water valve hope this helps good luck!!!!
Mar 28, 2010 | Home
Removal of moen #1248 cartridge
That was exactly the solution I needed for my Jacuzi bath tub with the two handle faucet. The use of the screw in the top of the cartridge was needed to be able to get a strong enough hold on the cartridge stem. Mine is all recessed about 2 1/2 inches so I grabbed the screw head and stem with long nose pliers, and then clamped down on the pliers with a set of adjustable pliers, and then used a 1/2 block of wood as a lever to get pressure on. That got the cartridge to pop out! Thanks!
Mar 27, 2010 | Moen & Replacement Cartridge
We have oil rubbed bronze bath/shower hardware.
it should be threaded into the popup assembly.
Mar 25, 2010 | Home
I have a Moen single handle shower faucet in my guest bath. Off is clock wise and hot is counter clockwise. Since I have lived in my condo, there has never been hot water coming through. Can you help me...
Pop out center of handle, and remove the screw from center, and remove handle. There should be a little nylon gear like sleeve that will pull out from center. Pull it out, and rotate it one way or the other, a little at a time, and slide it back in. Now just slide your handle on long enough to try it, no need to attach with screw yet until your done. May take a few tries to get it where you want it, then simply put handle back on, secure it with the screw, and snap cap back over screw.
Jan 19, 2010 | Moen & One Handle Tub & Shower Faucet
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Oct 09, 2009 | Porcher 5535-254.___ Reprise Pillar Taps...
Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Mar 02, 2009 | Delta T13420 Chrome Classic Single Handle...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Plumbing Logo
94 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
