It wont turn on the spinner light wont turn off
    Problem Solver:
  • 5 Answers
10-2009
Had the same problem. I took off the back, removed the battery and put it back in. And, now it's fine. Could be a form of resetting the unit. Found no directions on how to change the battery, I figured the battery was OK and was going to salvage it for another unit, But, now I'm back to 2 Sansa's. Found nothing on google to help with this problem. Good luck
Posted on Nov 12, 2009
Tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 | Cuisinart ICAPP-4
Cloths spinner wont rotate under load
EITHER bad motor are broken belt ,if u. Don't know how to fix dryer call for service
Apr 03, 2015 | Dryers
Flames wont turn on and spin around
The bulb may have failed. Heat from the bulb is usually what turns the spinner.
Oct 28, 2013 | Heating & Cooling
When you turn the spinner on it wont work i'ts geting power to it but wont spin but pumps the water out
Check that the drive belt is on (you can find this underneath the machine if its a top loader, or in the back if it's a front loader) If the belt is on, check that the pulley turns freely, you may possibly be looking at a seized bearing or gearbox.
Jul 29, 2011 | Washing Machines
Top rack spinner is not spinning
First check - ensure that the jets at the end of the spinner blade are not blocked. Check that the spinner is not siezed by turning it by hand, other than a cracked or disconnected pipe, there can not really be another reason for the spinner not rotating (if the bottom one rotates).
Jan 15, 2011 | KitchenAid Dishwashers
I put the game in but the disk does not spin
try cleaning the spinner and laser and make sure the spinner and game make contact to where they spin. it might be that your tray is kind of crooked and it misses the spinner to where the game wont spin.
Dec 08, 2009 | Sony PlayStation 2 Slimline Console
The spinner wont spin
clog, take bottom apart and clean, keep cleaning it theres more in there
Sep 07, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
Spinner for the plastation2
mine to same thing it sucks doesent it
Nov 02, 2008 | Sony PlayStation 2 Slimline Console
106 people viewed this question
 Grubhead
Grubhead
