Dryers Logo
Posted on Nov 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgot the lint screen
I ran the dryer without the lint screen and am now 'missing' some socks. The dryer makes a rumbling noise. How do I get the socks out and did I break something?
Sal De
Level 3:
  • Dryers Master 2,699 Answers
  • Posted on Nov 12, 2009
Sal  De
Dryers Master
Level 3:
Answers
2699
Questions
0
Helped
1003256
Points
8029
They are in the blower wheel duct,take the bottom panel off and take the duct off and you'll find you socks,you should also take that off once and a while and clean the lint out of it
2answers
Forgot to put lint screen in and something a sock is under the drum, how do I remove without calling a repair person, we are in a snow emergency and would like it done now for all the wet snow cloths
Hello, David -
This is a link to another question forum with two solutions in one person's answer:
https://www.shopyourway.com/questions/1198504
One involves unplugging your dryer and using a straightened wire clothes hanger.
The other solution (with the dryer unplugged) is to remove the back of the dryer and air duct housing. I do not know the make and model of your dryer, so I cannot provide a diagram of your dryer.
You may also find this answer to a similar question on Fixya in 2009 helpful:
http://www.fixya.com/support/t2618111-sock_fell_in_vent_whirlpool_dryer
Best wishes.
Jan 18, 2018 • Dryers
you better inspect inside the exhaust vent tubes for the socks. You did not break anything but they might start on fire later. You to take off the back of the dryer to take the vents apart.
Rumbling grinding
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Feb 17, 2015 • Dryers
Why is my divinci 6030 receiver making loud rumble noise when I push the power on in the back of unit. I have nothing hooked up to it.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Dec 17, 2014 • Dryers
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 09, 2014 • Dryers
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 • Dryers
1helpful
Sock fell down lint vent and daughter turned on dryer
Turn off you power to the dryer and then,
You could run a coat hanger straightened out with a hook bent on the end of it into the lint vent at try to hook the sock.
But probably you will have to remove the back to follow the lint vent.
You may try to remove the vent hose and run the straightened coat hanger in there to try and remove the sock.
Hope this helps
I ran the dryer without the lint filter in it and now it is noisy
First of all, You have a serious safety issue. Your dryer may catch fire. DO NOT USE YOUR DRYER.
Something went into the mechanism (yes, may be another sock), and a lot of lint went inside the dryer. The dryer needs to be cleaned by a technician. Using the dryer on its condition may cause a fire. Don't get your house burned down just to save some money doing it by yourself.
2answers
I took lint filter out to clean it and forgot to put it back in, I started gas dryer and it stopped, I believe there is a sock stuck in there somewhere. Does the front come off and what do I need to take...
Hello Kims987K,
You may want to check circuit breakers in your Breaker Panel to see if the one for your Dryer is tripped, and reset it if it is. Even though you have a Gas Dryer the Drum still operates on electricity, so without it the Dryer wouldn't function at all.
I don't think that the sock is stopping your Dryer, as the lint filter just filters lint from your Dryer's exhaust. So, even with the lint filter out a sock couldn't fit through the small holes in the drum that ventilate it (that's how the lint gets to the filter). I guess there could be a switch that detects whether the filter is in the machine and cut it off though, so you may try to re seat the lint filter (replace the lint screen/filter making sure it's in all the way), and try to start it again. If you look inside the Drum and see any way that a sock or anything else could get out other than through the door opening? That would be a problem.
If the filter was missing for several loads of laundry? Then you could have a restriction in the exhaust causing a thermal overload circuit to cut it off too (prevents the Dryer from catching fire). Does the light come on in the Dryer when you open the door?
From the information you posted, all I got is that it's a Gas Dryer that won't run and you appear to be missing a sock, so more detailed information will probably help in finding your solution.
I'll check back, and Good Luck finding that sock.
Mar 05, 2008 • Dryers
Top Dryers Experts
john h
