Question about HP LaserJet P2015 Printer
Cleaning hp 2015
Lost the book, need to know how to clean and perform user maintenance
  • 33 Answers
This would help a lot!!
good luck!
Service manual free for you to download...
hope this helps,
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P2015%20Series%20Parts,%20Service%20Manual.pdf
Posted on Jan 21, 2010
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
Hp Color Laserjet CM4730 MFP printer. The problem is on the output copy from the ADF showing a line on the edge. But from the glass scanner, the print out is ok
I think that ADF of the printer is causing the issue and requires cleaning. Fortunately, HP Official support has provided the details along with pictures about maintenance/ cleaning of the ADF Unit.
Cleaning the ADF delivery system
Please visit the above link and follow the procedure to perform regular maintenance of the copier.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | HP LaserJet 2840 Printer
Can the pump's pressure be turned down? The water come out of the jets really hard and fast and our electric bill has more than doubled since the pool pump was installed. Friends with similar pools...
I think you mean "1.5 Hp" because a "15 Hp" is just crazy, LoL Pumps are matched to each pool when they are built, so there is no need to go to a larger size pump (Higher Hp). If you can't return/swap the pump for the correct hp you had removed, you can have a smaller Impeller installed on the pump.That will reduce the flow,and also use less electricity.As far as maintenance... Clean out the basket from time to time,Lube the lid o-ring with pool lube ONLY, and keep an eye out for leaks.
Sep 27, 2010 | Pentair 15 Hp Superflo Swimming Pool Pump
PRINTER DOES NOT PRNT PICTUES CORRECTLY. THEY ARE RED AND GREEN AND BROWN MOSTLY. CARTRIDGES SHOW LOW EVEN WHEN NEW.
Go to your printer's Maintenance Utility and perform a Head Cleaning or something that is similar. For Windows users:
  1. Click Start => Control Panel
  2. Click on Printers and Faxes (or devices that list printers)
  3. On the printer's folder, look for the printer name and right click on it and click properties.
  4. Select the Maintenance Tab on the dialog box that appears
  5. Then choose something like "Head Cleaning" and perform the test
Jun 23, 2010 | HP Photosmart C6380 All-In-One InkJet...
Lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Printing below standard
The problem could very well be clogged ink or air bubbles. There's no need to perform the regular cleaning any more as if it didn't solve the problem in the first few tries, it wont help, more force is needed.
You can perform a powerpurge (takes more ink, uses more force, solves more clogged ink), to perform it, follow these steps:
  • Enter maintenance mode, press menu, 2, 8, 6, 4 quickly (in two seconds).
  • When the buttons are flashing and the display says Maintenance, press 7, 6.
  • The display should now say "CLEANING ALL", press 3.
  • Now it should say something among the lines P_PURGE or POWER_P. Press Mono/Black Start.
  • After cleaning is done, you will get back to Maintenance. Press 9,9 to leave service mode again.
If the problem isn't solved now however, chemicals would probably be needed to solve it, as this is pretty much the only "function" you can use.
May 26, 2009 | Brother MFC-260C All-In-One InkJet Printer
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC-210C
First ensure that none of your inkjet cartridges are empty or near empty. The machine will not perform cleaning if any cartridge is too low on ink. If the conditions are met the machine at least attempt perform the cleaning function. There is no guarantee that the print quality will improve on the first try.
Sep 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Print Stripes
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00226&lc=en&cc=us&dlc=en&product=304445&rule=42852&lang=en HP has indications that the lubricant on the printer carriage assembly tabs and the flex circuit contacts on the print cartridge can collect debris (fibers and dust), which may cause poor output. The lubricant is used to ensure that the interaction between the pen and the carriage assembly does not cause tears in the flex circuit. Refer to the following instructions to solve this issue. Cleaning the Inkjet cartridges can improve the quality of printing. If the printed page is missing lines or dots, or if it contains ink streaks, perform Procedure 1 in this section. If problems persist after performing Procedure 1, perform Procedure 2. NOTE: Use plain paper for these maintenance activities rather than more expensive specialty papers. Procedure 1: Cleaning the cartridge electrical contacts 1. Turn on the printer. 2. Open the top cover. The cartridges should move to the center of the printer. 3. Unplug the printer?s power cord from the power outlet. WARNING: Keep new and used cartridges out of the reach of children. 4. Remove the color cartridge. 5. Clean the electrical contacts (see Figure 1). Figure 1: Cleaning the cartridge electrical contacts A- Use a clean, soft, dry, lint-free cloth. B- Locate the copper-colored circuitry strip on the back of the cartridge. C- Wipe the coppers strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. CAUTION: Do not wipe the nozzle plate on the bottom of the cartridge. Wiping the nozzle plate can damage the cartridge (Figure 2). Figure 2: Do not wipe the nozzle plate 6. Remove the black cartridge. With a clean part of the cloth, repeat Step 5 with the black ink cartridge. Cleaning the electrical contacts inside the carriage assembly 1. Look for fibers or other contaminants on the electrical contacts inside the carriage assembly. The contacts in the printer can be damaged if too much pressure is applied during the wiping process. If necessary, the contacts may be cleaned by wiping them very gently with a dry, lint-free cloth (see Figure 3). Try to gently remove any visible debris within the carriage. WARNING: Make sure the printer power is turned off before cleaning inside of the printer. Figure 3: Cleaning the contacts inside the printer 2. Reinsert both cartridges. On models with cradle latches, close the cradle latch over the top of the cartridges. 3. Close the top cover. 4. Plug the power cord into the power outlet. 5. Print a test page. If the problem persists, go to Procedure 2. Procedure 2: Aligning and cleaning the cartridges Use the HP Deskjet Toolbox or Printer Assistant utility on the desktop (the utility name will depend on which HP Deskjet model is installed on the computer). NOTE: HP Deskjet Toolbox or Printer Assistant is for Windows users. HP Deskjet Toolbox: To align the cartridges from the HP Deskjet toolbox: 1. Open the HP Deskjet toolbox. The toolbox is located on your desktop in Microsoft ®) Windows XP, Me, 2000, 98, 95, and NT 4.0. In Windows 3.1x, the toolbox is located in the program group for the printer. 2. Select the Printer Services tab in the toolbox. 3. Select Cartridge Alignment and follow the steps on the screen. 4. After the alignment process is completed, perform a Cartridge Cleaning from the toolbox. 1. Double-click the HP Deskjet Toolbox shortcut (or icon) on the desktop. 2. Click the Printer Services tab. 3. Click Clean the Print Cartridges. Follow the instructions that appear on the screen HP Printer Assistant: To align the cartridges from the Printer Assistant: 1. Launch the Printer Assistant by clicking the Printer Assistant icon located on the desktop 2. Select tools and updates. 3. Go to printer maintenance. 4. Select calibrate printer. 5. Click calibrate and follow the onscreen instructions. Further instructions on calibrating the printer cartridges using the Printer Assistant can be found on document npd09616 - HP DJ 3320,3325 and 3420 series printers - how to calibrate the print cartridges After the alignment process is completed, perform a Cartridge Cleaning from Printer Assistant. 1. Select tools and updates. 2. Go to printer maintenance 3. Select clean cartridges. 4. Click clean and follow the onscreen instructions. If the problem persists, the cartridge should be replaced. If the cartridge still exhibits banding even after cleaning and priming actions in the HP Deskjet Toolbox are complete, the cartridge may need to be replaced. Verify the end for warranty date on the supply before returning it to the reseller. Typically, banding problems are most pronounced in images produced on plain paper in Normal mode. In many cases, simply changing to Best mode will alleviate the problem and produce satisfactory output. If switching modes does not result in acceptable performance, try using the cleaning steps described above. Internal test from the printer Running an internal test from the printer can perform a clean test. See document titled HP Deskjet Printers - How To Print Internal Tests for instructions on how to run internal tests. If the problem persists, replace the cartridge. Let me know if that helps. Good Luck, Tim
Mar 15, 2007 | HP DeskJet 5650 InkJet Printer
HP LaserJet P2015 Printer Logo
752 people viewed this question
Seeker5211
Seeker5211
