Question about Samsung SyncMaster 203B LCD Monitor
After you turned it on and the screen blacked out
Scree blacked, shined a flashlight into the screen and can see the icons and image. How to open and replace lamp?
  • Samsung Master
  • 1,684 Answers
It sounds like you just have a bad backlight power supply. Go to our web site at: www.ccl-la.com We have repair guides for many models of LCD monitors and the 204B guide should also work for your unit.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Nov 14, 2009
My tv has a black screen and not images but the audio works fine
Shine a flashlight from the back of the screen, if you see and image your backlight is burned out, if no image you have more serious issues.
Feb 23, 2017 | Samsung Televison & Video
Why won't it turn on?
While it is on, shine a bright flashlight on an angle across the surface away from you. Can you see any faint images on the screen. If yes, then possibly the back lit lamp / board needs to be replaced.
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
Nov 25, 2015 | Televison & Video
Screen black, no video have audio. Went black at some point when I was distracted. Have tried unplug/pause/repugnant - no help. On/off did nothing either.Vizio, Mdl- VO320E, LCD. Not listed on your...
You need to perform the flashlight test. Turn off the lights in the room, turn the TV on, take a bright flashlight and shine it on the screen. Do you see the faint image on the screen?? You could have a defective backlight inverter, defective power supply, or a main board issue. You set will require diagnosis to determine.
Jun 04, 2012 | Televison & Video
While using my compaq cq61-412nr notebook my scree will suddenly go blank when i open and close the lid a coulple times it returns then blackouts again
It sounds like you have a bad LCD DC inverter board. This device low voltage DC current into high voltage AC current, which is required to power your LCD screen's back light. Here is a simple test to determine whether your DC inverter board is bad:
1. Power on your computer 2. If the screen initially turns on, either wait for it to go black, or perform any action that you know consistently makes it go black. 3. Find a standard flashlight and shine it directly at the screen. If you can see your display with the light shining on it, then your inverter board needs replacing. You may need to maneuver the flashlight to a particular angle to see the display through the glare of the flashlight on the screen.
Replacing the DC inverter board is inexpensive, if you are moderately experienced with the mechanical aspects of laptop computers. The replacement part will run you between $20 and $40 (here is one that fits your computer for approximately $20: http://www.zlectronic.com/product/For-Compaq-presario--cq61-412nr-Laptop-Lcd-Inverter-Display-Replacement.html). You should not attempt to replace the component yourself unless you feel confident about what you are doing. If you feel better having an expert perform the job, consult different computer repair shops in your area for a price quote on the labor. Be sure to let them know you will be supplying the part yourself; if you have them obtain it, you will almost assuredly be charged a mark-up.
If you found this solution helpful, please leave a positive rating!
Jul 18, 2011 | Compaq Presario CQ60-204NR Notebook
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
Blank screen
Take a flashlight and shine it on the screen. If you can see an image, you probably need to replace the power inverter board. It supplies power to the backlight.
Jan 23, 2010 | Toshiba Satellite M305D Notebook
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
Screen went black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. You have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside. Some of them were broken and it is very easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to do fix it.
Mar 06, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Screen goes black
Hai,
Do you see any dull image on the screen ?
If yes the inverter Card/Backlight of the screen is having problem.
Regards,
Aby
Dec 22, 2007 | Rosewill R900J 19" Flat Panel LCD Monitor
Problem with monitor going black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU1.gif and monitor. After it goes black, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Oct 30, 2007 | Relisys RLT1720 17" LCD Monitor
Samsung SyncMaster 203B LCD Monitor Logo
377 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
