For get Wireless Router
I for got my Dp link wireless router can you help me about this problem i wait for you answer thanks bye..
  • Computers & ... Master
  • 2,263 Answers
Are you trying to connect to the wireless network or you forgot the wireless settings of the router ?
You will need to check the wireless settings of the router.
It is easy,
Click Here for more info
Posted on Nov 12, 2009
I have EarthLink Internet modem is a zyxel p-600 can I connect a wireless router? And if yes what kind should I bye or can it be any wireless router?
yes you can add any wireless router to your network and configure one setting in your new wireless router called default route
the default route to your existing router ip address
for example your existing router ip is 192.168.1.1
your new wireless router ip is 192.168.1.254
you need to put ip net 0.0.0.0 mask 0.0.0.0 default gateway 192.168.1.1 in your wireless router
thats all
thanks
Apr 13, 2013 | Computers & Internet
Change the name and lock connection
Hi! Welcome to www.fixya.com.You can find the answer you need here: Just enter the link in to your browser.http://www.howtodothings.com/computers-internet/how-to-protect-a-linksys-wrt54g-router-using-wap-and-wepHope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Jul 23, 2011 | Linksys Wireless-G WRT54G Router
I have comcast interenet and a hiro wireless router. i get signal on my computer but i can not load a site. i have a mac. any help?! thanks!
Hello and thank you for your question,
Your router may need to be power cycled. To do this please:
1. Unplug the power source from the back of both your modem and wireless router.
2. Wait 15 seconds
3. Then plug the modem back in.
4. Wait a minute.
5. Then plug the wireless router in,
6. Wait two minutes.
7. Restart your computer and you should be fine.
If this does not solve the problem you should contact the router manufacturer.
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Guru: zdeuyo
Mar 28, 2011 | Computers & Internet
I forgot my parent controls pin
As far as I am aware, the only way to reset the pin, is to reset the router to factory defaults. You will then have to reconfigure your wireless settings. To reset to factory defaults:
Plug in the router.
1. Locate the small reset button. It is next to the power jack.
2. Use something to push the button, a paper clip works well.
3.Hold the reset switch down for 10 seconds.
4. Wait for the WLAN light to stop blinking. The router is now reset.
To reconfigure the settings on the router, enter 192.168.0.1 into your browser address bar.
Mar 14, 2011 | D-Link AirPlus DI-524 Wireless Router
How to access homepage of dlink DP-301 P+ print server, when u have forgotten its ip address
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 07, 2011 | D-Link DP 300 (DP-300) Print Server
Password on wireless router
OK, You listed this under a print server router. I looked up the DP 300 print Server router and restricting access to the router is not an option. If you are actually talking about your Wireless router for your home network you need to look in the user manual or access the router and go through the configuration pages for the wireless settings and set Security to on and then Select either WEP or WPA as the security format, which ever is supported by your computer, then enter a Security Key. The Key can be anything as long as all devices that are going to use the wireless have that same key entered with the same security method selected. Your user manual should explain better where these option are located.
Jul 26, 2010 | D-Link DP 300 (DP-300) Print Server
How to connect a netfear router to a dell computer
I assume the Netgear is a wireless router and you want to connect to the router using a wireless connection.
Make sure the DELL computer wireless card is installed with the latest wireless card driver.
The Netgear router needs to be configured with the wireless settings ie SSID and encryption etc.
Next the wireless card needs to be configured with the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
Yes but where do i find a wireless router at
You check whta should your buy here..
http://www.ehow.com/how_2009129_wirelss-broadband-router.html
and you can buy from....
http://www.amazon.com/Linksys-WRT54G-Wireless-G-Router/dp/B00007KDVI
Hope this helps, let me know if you need more assistance.
Kindly rate the solution if i was helpful. thanks kevin
Mar 24, 2009 | Acer Aspire 5315 Notebook
LOST THE CD FOR MY WIRELESS ROUTER
Belkin dosent seem to have your model (anymore??)
But here is the link to contact them:
http://www.belkin.com/support/contact/email/technicalsupport/
Bye the way, I WOULD NOT install the wireless software on a wireless pc, as configuring a Router with a wireless conection is bound to create problems, - take it from someone who KNOWS.
Nov 29, 2008 | Belkin (F5D7633UK4A) Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
