Question about Lands Phones
Need help how do you change ringer number so it rings longer then 2 times
RAISE THE NUMBER OF RINGS
Posted on Nov 12, 2009
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Voice Mail
go iin option under ringers cheak to see whats its on before voise mail picks up 1 3 6 10 ? isnt it in the optimns menu or if u have seprate unit for voise mail cheak setting on that beofre it grabbs the call does that help
Jan 07, 2008 | Lucent 1872 Corded Phone
How do I set the ringer on DECT1635 to ring for longer
Hi there
Try this: -You can set or change the answering system options from any handset.
Just open the menu and select Answering Setup. Select Ring Time and Set the number of rings (6, 9, or 12) before the system answers. Toll Saver makes the system answer after 2 rings if you have new
messages or after 4 rings if you don't.
I also found a full manual which you can download from here:
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/DECT_1635_OM.pdf
and save to your computer for future reference
Cheers
Nov 11, 2014 | Lands Phones
Our digital answering feature now picks up after 2 rings, it has always rang 4 times. Is there a way to adjust back to 4 rings?
click menu 3 times. click either repeat/rew or skip/ff to set to either 2 for 2 rings or 4 for 4 rings or 6 for 6 rings or h5 for toll saver THEN press set/ringer to save your change. Answering machine will answer after 4 rings if you wanted the 4 & saved by pressing set/ringer. Thats all there is to it.
Mar 29, 2010 | Uniden Cordless Phone exai398i
Unknown callers wont ring
maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Apr 20, 2009 | Motorola Mobility Moto Q
Prostar 816 need to turn ringer on
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
hope that helps
Jan 30, 2009 | Samsung Prostar 816 Phone
Ringer
press #when finished. hope that helps
Jan 27, 2009 | Samsung Prostar 816 Phone
Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Sep 03, 2008 | Nortel T7316E 2-Line Corded Phone
How can I change the number of rings?
Not sure what you are asking. Are you saying your phone only rings twice before going to voicemail?
Mar 27, 2008 | NorStar M7310 Corded Phone
Phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
May 10, 2007 | Panasonic KX-TG2303B/WH Digital Cordless...
Lands Phones Logo
221 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
