Question about Panasonic DMR-E55 DVD Recorder
Horrible noise on hard drive
When i go to the hard drive and view what i have recorded, there is a horrible scratching noise, like 2 speaker wires touching..it is on all recordings. have not had a problem in the past
  • taykn002 Nov 14, 2009
    It hasn't been dropped...when I plug red AV plug in the noise starts...I reckon the AV output plug is dodgy...Can this be repaired?
    Problem Solver:
  • 13 Answers
Your player has probably been dropped. I would take it to your nearest Panasonic center or store and get it replaced or buy another E55. Repairs are going to be costlier than the unit itself.
Posted on Nov 14, 2009
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
LOUD HUMMING NOISE COMING FROM SPEAKERS
Could do with a service.
Check the turntable motor and drive plus check the cartridge and signal wiring.
Sep 14, 2017 | Wurlitzer Jukebox CD Player
My speakers started buzzing and making a horrible noise during the night. I had to unplug them to get it to stop. What's going on?
Feedback. Check the wires, might have a bad connection. Wiggle them around and see if the buzz sound stops or changes. If that happens, its usually that wire. Good Luck.
Sep 10, 2009 | Harman Kardon HK695 Computer Speakers
My external hard drive fell, and now my computers are not reading it. It makes some funny noises, then the front light stays yellow, and it halts any activity.
ok disconnect the hard drive,put the hard drive in an air tight bag/container and put it in the freezer/fridge for about 2 hours then remove the hard drive and attach it and then check it should work now,if you still hear the scratching one of the discs inside the drive has been dislocated or damaged and so in a closed room open the hard drive if you are not afraid and you'll be able to re-settle the disc if its dis located,however if else try what i mentioned above and ignore the scratching sound,
I have tried this and its worked for me
Aug 11, 2009 | Computers & Internet
Locate Speakers for 2006 Ford Expedition Limited
If you are installing a radio, you can use a small 1.5 volt battery and scratch each pair of wire, this would make a scratching noise which tells you which wire is for which speaker. Other than that i don't know the reason for locating the speakers.
Jun 30, 2009 | 2006 Ford Expedition
Trying to fix an old record player - Califone. It seems to be making a scratchy sound even though I have replaced the needle. It almost sounds like when the two wires from a speaker touch... same...
May be the "winding" on the speaker. If it has got damp at some point(you may not notice any on the casing) the cardboard tube that the coil is wound around swells and "rubs" in the speaker. Thus producing a scratching sound. Try connecting to another speaker, just to test and if it sounds fine then that is what it is.
May 14, 2009 | Califone International 1030AV Turntable
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Panasonic DMR-E55 DVD Recorder Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
