Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't find a husqvanna chain saw carburator adjustment tool . It's for a 16" blade. There is a little hole that a tool goes into for adjustment. A screwdriver won't work. Help?
    Sniper:
  • 197 Answers
You may have the one that uses splined adjustment screws rather then limiters.If you do you can order this from your husky dealer.You can tell if you have limiter caps by shining a light through the screw hole and see if caps are white or red.If black you have round splined needle ends that take a hard to get adjustment tool.
Posted on Nov 18, 2009
  • 486 Answers
It is a very thin and narrow screwdriver slot. A screw drive from a small kit used for eyeglasses should work
Posted on Nov 12, 2009
How to put the chain back on a 16" Poulan electric chain saw
its probably like the gas model. so you remove the 2 nuts holding on the side cover of the blade side, remove the cover and the blade and chain. To fit back, slacken the adjuster screw a little bit, or if fitting a new chain then a fair amount, as you have to be careful that the pin on the adjuster fits into the proper hole on the saw bar, as you fit back on the bar, of which you have already cleaned out the grooves. supporting the bar in the slackest position, fit on the chain, making sure that the cutting edge at the bottom is coming towards the motor. Then slide the bar and chain away from the motor to take up the slack, then fit back the metal guide in the original position, fit cover with the adjuster pin in its hole on the bar, and replace the 2 nuts almost tight but slack enough to use the adjuster to set the chain to cutting position..slightly sagging on the sprocket nose type, or snug on the solid nose type..then tighten the cover 2 nuts firmly but not excessively as that will damage the machine..NB the bar & chain depends on the adjuster, not on the nuts tightness to maintain tension
Jul 14, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
How do i replace the chain saw blade on my homelite 3514c chain saw show pictures
just unbolt the blade cover adjust screw to loosen chain and remove simple as that p.s that is the side that the bar is on hope this helps if not get back to me
Oct 06, 2013 | Homelite ZR10926 16" Chain Saw
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
Chain is not getting oil
Start with the simple:
  • Make sure you have enough oil in the tank.
  • Then take off the bar and clean any saw dust out of the bar groove, especially by the oil holes. This can be accomplished with a raker adjustment tool or a putty knife. Next clean the oil holes in the bar and oil slot on the saw head.
  • If this doesn't solve your problem, your oil pump may need adjustment, or replacement.
  • Your owners manual will have the directions on how to adjust the oiler.
Sep 15, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
What tool do I need to adjust the high & low speeds of the carburator for my Poulan Predator 35cc chain saw because it will not idle at the proper speed.
Should just be a little bladed screw driver, most are, turn the screw very little, 1/4 turn at a time till something changes, they are sensitive. If you run out of adj and nothing has changed, turn the screws in all the way, both of them, then out 1 1/2 turns, this will get you running, you can fine tune from there.
Aug 29, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Homelite Ranger 16 inch chainsaw starts great runs smooth but upon cutting in to any sized branch or tree it now bogs down and stops cutting. Whats strange is that doesn't die it keeps running but will...
My 16" Ranger had the same problem. Here's how to fix it. Take off the top cover and the red side cover to acess the carburator. Take the top off the carb; there is a single screw that holds it on. Inside you will see a 10mm round indention. This is a final screen fuel filter. Mine had a layer of light brown dirt over the screen. Take a small screwdriver and carefully scrape the dirt off. You don't need to clean the carb any further or adjust the H and L settings or anything. Put it back together and it should run with no bogging. down.
Mar 20, 2010 | Homelite ZR10926 16 Chain Saw
I have a 435 side tensioning and after around 30min of use the side mounting slackens cousing the chain to come off damaging the chain
What is happening is the chain is heating, and expanding.
Make sure you have a full tank of oil, and the recommened blade for your saw.
Also make sure the bolt(s) are not damaged on your adjuster.
Feb 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
Poulan 46cc has very little power
you need to adjust the gas an air on those two little screws on the carburator
Feb 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
199 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
