Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
Start the oven and it turns on for a little while and then alarms and shows F10 on the display and beeps till you turn it off
  • 15,935 Answers
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
What does code f10 mean?
get a small oven thermometer and put it inside the over to check what temp it goes off at .many times it is a bad thermocouple .
Sep 25, 2015 | Kenmore Ovens
Hi, My oven has been beeping a F10 error code for some time now, and I would like to know how I can fix this problem?
This is from Frigidaire website
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press STOP/CLEAR to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
If the code is still displayed after you've followed these steps, contact your local authorized service provider.
That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
Joe
Aug 30, 2011 | Frigidaire FGB24L2A Gas Single Oven
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Oven beeps and shows F7.
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
Jan 08, 2010 | Kenmore 33169 Gas Single Oven
Oven F10 Problem
PJC,
From the Frigidaire service manual:
"F10: Runaway Temperature.
SUGGESTED CORRECTIVE ACTION
1. (F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive."
-hopefully it's just a bad temperature sensor!
www.fixyourboard.com
Jul 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
