Question about Farenheit MDM-830CM Car DVD Player
Farenheit car dvd player says disc error, i have used a cleaning dvd on it, and my hubby used his air pump and blew it out. any other suggestions?
    Problem Solver:
  • 7 Answers
First where did u buy your dvd from if u got it from walmart it will not work due to the copywrite walmart put on its disc and if its a burnt dvd hang it up if not your laser has gone out so take it back or get to your nearest repair shop
Posted on Nov 12, 2009
Hi i have a Farenheit tid-530 and when i play the cd on the dvd player it randomly turns off and switches to the fm radio is there any solution or is there a problems with the wires?
When mine did this i bought a cleaning disc and it stopped this. Untill a few months later. Just use it once a month or so and it shouldnt happen anymore.
Jul 10, 2011 | Farenheit TID-530 Car DVD Player
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
XV-N40BK/XV-N44SL (NO DISK INSERTED)
Hey WeiesBlitz,
There may be a number of reasons why you may be encountering this problem, but there are a couple of quick solutions that may always try before seeking repairs on the player.
First, I would suggest making sure that the DVD's being used have been cleaned and are dust-free. Imperfections or impurities of any kind on the surface of a CD or DVD may prevent the laser in your player from being able to read, or even recognize the media inserted. You should be able to clean the DVD by using a soft and dry, lint-free (typically microfiber) cloth. Remember to try using gentle, outward strokes that run from the inner ring of the disc directly to the outer edge.
Second, you can always try cleaning the lens of the player itself using a commercial cleaning kit. Many retailers (including your local Best Buy™ store) may sell kits that clean lenses when inserted into your player like a normal DVD. Please keep in mind that not all DVD players are designed to function with these cleaning kits, and that you should always refer to your owner's manual for any possible warnings against the use of such products.
Should these suggestions fail resolve the problem, you may wish to try using other DVD's from your film library in the player. If other discs function normally, the non-functioning disc may be damaged. If using other discs results in the same error message, the player may be in need of physical repairs.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 06, 2008 | JVC XV-N40BK DVD Player
Bad Disc
Try using a lens cleaner and see if that resolves the issue. Also see if this error occurs with all discs or just a particular one. If it happens with all discs, then it is a lens problem. If it happens with just a few, then its likely that the disc itself is scratched or defective.
If the lens cleaner does not resolve the issue, then you will have to open the cover. Try using a can of compressed air to clean out the insides. Also, clean the lens itself with some isopropyl alcohol and a cotton swab. If the lens is scratched or dirty, you may have to replace it, in which case, it would be cheaper to simply buy a new player.
May 25, 2008 | Philips DVD 622 DVD Player
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
"No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
No disc
Sorry no luck with a manual yet best I could come up with is e-mail address; Tech-support@Farenheitusa.com They should help. It does sound though as if you have to either get it serviced (try your local repair shop) or replace it - I will keep looking for a manual and post anything i find; Hope this helps :)
Mar 18, 2007 | Farenheit DVD34 Car DVD Player
Farenheit MDM-830CM Car DVD Player Logo
192 people viewed this question
Top Farenheit Car Audio & Video Experts
Michael Vincent Cruz
xxxxxx xxx
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
