Question about Car Audio & Video
Why did my pyramid legacy 300x2 stop working
Why did my pyramid legacy 300x2 just suddenly stopped working and the protect light came on?
  • Perry Babin May 11, 2010
    If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low. If both the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
    Novelist:
  • 92 Answers
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. ANOTHER PROBLEM WHICH IS A LITTLE RARE, IS THAT SOMETIMES THE RADIOS REMOTE OUTPUT WILL SAG BELOW 11 VOLTS AND THE AMPLIFIER WILL NOT TURN ON. IF YOU CANNOT MEASURE THE REMOTE LEADS VOLTAGE, SIMPLY DISCONNECT IT AND TEMPORARILY INSTALL A JUMPER BETWEEN THE POSITIVE TERMINAL AND THE REMOTE TERMINAL OF THE AMPLIFIER AND THIS SHOULD FORCE THE AMPLIFIER ON, BUT IF IT DOES NOT, IT WILL DEFINITELY NEED SERVICE, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
My dash lights on my 1997 subaru legacy outback just stopped working out of no where, What could be the problem?
ok fuse boxes are under the hood and under the dash around the hood release lever. should be the 5A fuse
Dec 27, 2013 | 1997 Subaru Legacy
300W Pyramid PA305 protection light
What is the speaker load in Ohms that you are running? Or what exactly is hooked up to it? are you bridging it? The protection light will come on if the load is too much for the amp to handel. If the load (in Ohms) is less than the rated load that it can run, it will stop the output to keep the amp from self destructing. The amp will sense that the demand for power will be too high for the amps circuitry which will either make the amp get so hot that it will burn up the copper on the board or more likely burn up the power mosfetts that power the speakers. If the Ohms are within range then it will allow power to flow through the circuit until the rails that the mosfetts are bound to until they get so hot that it will go into thermal protection. So if your amp has both thermal and overload protection lights and the overload is light then the load is probably too much for the amp. if it's bridged in mono the you can only have 1 speaker setup hooked up it if it's a 2 channel amp. a 4 channel amp bridged in mono for both front and rear channels will be able to have 2 speakers rated a 4 ohms each hooked up to the amp 1 set per bridged output or channel.
Try it running in stereo with only 1 speaker per channel and see if it will produce sound. If not then you have an amp that has internal problems and will need to be serviced. Check your warranty to see if you are covered.
Apr 02, 2013 | Pyramid PA305 150 Watt PA Amplifier Car...
Battery light brake light and stop lamp light on
Sounds like you have a broken belt for the alternator and power steering.
Jun 04, 2010 | 1991 Subaru Legacy
Pyramid PB1500 vs. Metrik Rem. Bass knob????
Yeah it's probably not going to work because it's not even the same brand
Jan 18, 2010 | Pyramid PB1500 Car Audio Amplifier
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
May 29, 2009 | Pyramid PB1217X Car Audio Amplifier
Pyramid PB449X In Protect Mode
The protect light is a notification that the amplifier has reached a set temperature and shuts the amp down till it cools off. Look for the thermosister on the heatsink and follow the circuitry back to the control chip. Once you get that fixed the amp should power up until it gets too hot and the protect circuit kicks in. I had one of these amps for a while and the circuit was very touchy. Regards, rcampsr
Feb 20, 2009 | Pyramid 1000W 2CH SUPER BLUE AMP Car Audio...
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Pyramid PB681X
You didn't say how long it ran before it quite and I assume the red light you are refering to is the protection circuit engaged light and not the power on light. But from the info you did provide, I'd say that it sounds like you may have blown some of the main output transistors/MOSFET's. If so, it's time for a trip to the repair shop. Sorry, for the bad news. If just turning your car on caused the outputs to fry, then I wouldn't be surprised to find that you have either bridged the speakers wrong or by some means you have put the wrong speaker load on the outputs. Ask someone who knows what they are doing, if you have your speaker loading correct. This person might not be a car stereo installer as sometimes they don't know how to load an amp correctly, especilly when it comes to bridging. Good luck.
Dec 30, 2006 | Pyramid PB681X Car Audio Amplifier
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
